Old 10-06-2002, 11:31 PM
Smurf Smurf is offline
Lube Master
Send a message via AIM to Smurf
Link to safe motor lube!
This was mentioned in another post im supplying the link here. Just spray this stuff into the 2 holes in the end of your motor to lubricate it. Heres the link i emailed them on prices ill post them when they contact me. http://www.miller-stephenson.com/release_004.htm its called Contact 'Re-NuŽ & Lube' I hope this helps i plan to order some soon
Here are the prices. You must buy 4 cans or more tho
MS738M (8 oz can) $12.50 each
MS738SP (4 oz can) $ 7.50 each
Both are stock items, and would ship from our Danbury, CT facility via FEDEX
ground. Should you decide to order, please call 847/966-2022 or fax
847/966-8468 your order.
Old 10-07-2002, 12:00 AM
sine -''-..- sine -''-..- is offline
Send a message via ICQ to sine -''-..- Send a message via AIM to sine -''-..-
yea i think its the stuff on the top. note that it says 'safe for plastic' thats important. if you can get it as just a liquid instead of spray, it would be even better, as you only really need to soak the motor in it to get it totally lubed up. plus the spray can seems to be very cold, and makes frost on the thing you're spraying on.
im sure it would be a good item for the store if you can get it in smaller quantities. eh tiny??
Old 10-07-2002, 01:03 AM
dumboi07 dumboi07 is offline
Send a message via AIM to dumboi07 Send a message via Yahoo to dumboi07
somebody said
that you can soak it in tv tuner liquid or sumthin. said they got it at radioshack
Old 10-07-2002, 09:33 AM
joeNuggetz joeNuggetz is offline
I dont think we need to mess with our motors unless they are totally about to die. There's no way I'm gonna lube up my motor. Dont you think there's already some type of lube/mechanism in there that is made for minimizing friction?
Old 10-07-2002, 04:23 PM
actofgod actofgod is offline
Bit Surgeon
I would be very curious to see how well this works. I'm all for screwing stuff up in the name of progress :-) Post your results when you get the stuff. Thanks for the info.
Old 10-07-2002, 11:24 PM
see the thing about the motors for bitcharg is that they're not supposed to be "high performance". they are very simple, as well as cheaply made so the commutator and such is very likely dirty even when it comes from the factory. im sure you could "break in" the motors by putting 3v on it, as ive heard someone do, or you could use something like this that'll clean off corrosion and stuff to make the motor preform better.
Laymans Tricell Link AE86 Toyota Bit Char-G / MicroSizers 5 03-28-2006 10:30 PM
Safe models for ZZ SE's in Canada? novastar512 ZipZaps SE 1 08-29-2004 09:58 PM
Here is a link to a 1/24 scale mph chart martin3103 XMODS 2 11-15-2003 11:08 AM
Is qfm Racing Safe ? RacerDeX ZipZaps 6 10-28-2002 07:09 PM
Replacement parts. Add a link to the FAQ? AceQ Bit Char-G / MicroSizers 3 10-22-2002 09:58 PM
