10-06-2002, 07:22 PM
13B REW
need help wit cheap clone!!!
hi again, i just brought a bit clone from a sidewalk sale and it was 10 $. wen i took it out i had 2 charge it 4 45 seconds but the lights tur off like at 27 seconds. but i let it charge 4 45 and wen i took it off it dont even move or make a sound  . its those clones that come in those round remotes called super racers. and it was a accord body wit a pink motor. it worked while it was charging but when i take it off it dont move at all.  . can any 1 help me?
10-06-2002, 08:19 PM
chek to see of the heat shield is on properly and then check to see if the pCB board is not pushed down far enough...try pushing down on the board and then go foward or backward.....
10-06-2002, 08:30 PM
13B REW
thx 4 the reply but i fixed it already  . it was the baterie inside , it was durty so i washed it wit alcohol. now it goes but the turning sux 4 it it turns automaticly sometimez. but wow it was fast. faster then my 3.o motor! and the antena was good . it went far like up 40 feet! its almost as good as my bit char-g! but it cant turn good . is there a way i could put that pink motor on my bit cuz i tryed 2 but it's just wont fit cuz its a bit bigger just barle bigger den my 1.0. i tink its a 3.8 but its kind of loud. the thing that is strange about this motor is that the silver tab is in middle.so is there a way 2 put this motor on my bit?
10-06-2002, 09:42 PM
deviant bit char-g pro
If that clone has a swaybar, it might be pressing on the steering knuckle pins that go through the top holes in the steering assembly. Just bend the sway bar so that it doesn't put so much pressure on the knuckle pins. I had a bensu thunderbolt oem bullet and the steering on it acted exactly as you described. Now it works just as good as my real Bits! Hope this helps
10-06-2002, 09:48 PM
13B REW
r.c dealer wats a sway bar? any pics???
10-06-2002, 09:57 PM
Spelling..........Grammer..............punctuation young grasshopper.
Actually, I am myself having a problem with my steering. My steering adjustment lever is all the way over to my left side (car upside down).
Yet it still goes to the right (car right side up).
Help?
10-06-2002, 10:01 PM
yellow fish forever!
the sway bar is the little piece of plastic that rattles around (maybe doesn't rattle much on bensu clones) and sits on top of the steering knuckles on top of your car. you can try to pop it out by using a dull knife and prying out one of the sides, and holding the other side down with your finger so it dont go n' fly out the window.
hope that helps...
10-06-2002, 10:09 PM
13B REW
is it the white thing on top of the weels? its stright from the middle and curves in bothe ends? and is the knuckles the thing holding the weel?
