Old 12-23-2003, 10:35 PM
sawhit4 sawhit4 is offline
Send a message via AIM to sawhit4
Please Respond Soon!!!!!!
ok i have a question about the mini x. i ordered the $95 from www.tinyrc.com and i got it in the mail but because i forgot to order the charger i will not be getting it untill after christmas. i was wondering if you can run the car off of regular AAA batteries without any mods to the car. i want to do this just untill i get the charger. on the car are the batteries soldered into a pack or do they use springs to complete the connection? please help me if you dont understand what im trying to say just ask because i can word it different. Thank you very much for any information you give me on this topic in advance.
EDIT: i noticed that the car is a 5 cell. with this setup are they soldered? if they are can you change it to the 4 cell setup? im not looking for speed while im waiting i just want it to run.
Old 12-23-2003, 10:47 PM
diets diets is offline
Hi sawhit4!
You can use regular AAA. But you need some springs for the battery compartment. They are option parts and i don't know if tiny add's them to the pack they sell. You can make your own springs out of thin steel wire. Search for a picture of the springs, it may help you to build a set.
Otherwise you can solder a battery pack by yourself, a lot of work, cause the batteries won't last long
diets - hopes this helps
Old 12-23-2003, 11:02 PM
thanks alot that does help i hope they come with the set but if they dont i think i can make my own.
namuna plz respond to this post musclecars4life XMODS 1 10-23-2006 12:24 PM
Will perfection 3.8 and 150 mAH NiMH cell work with my zip zap? Please respond ASAP. ibbored ZipZaps 5 09-11-2003 11:25 AM
What car should i get????(please respond!) Jemac Bit Char-G / MicroSizers 15 03-01-2003 04:15 PM
Fast Gears!!!!!! met-sb Bit Char-G Mods and Projects 3 01-24-2003 08:07 AM
