Old 12-23-2003, 06:55 PM
badboy727 badboy727 is offline
sharper turns
i have a skyline and my cosin has a supra and his goes sharper.I what to now if there is a upgrade or any why for my to make them sharper
Old 12-23-2003, 07:06 PM
itsme
AWD upgrade kit at Radioshack...
Old 12-23-2003, 07:18 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
No not AWD, get the suspension upgrade, it had tierods upgrades too so u can have sharper turns
Xmod Parts Help
itsme
AWD gives you sharper turns.
Old 12-23-2003, 07:43 PM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
I dont think AWD gives you sharper turns...it just gives you better traction. I would go with the suspension upgrade....... 4.5 tierod
Old 12-23-2003, 08:10 PM
OverBoostSupra OverBoostSupra is offline
AWD slows you down. I got the suspension upgrade and mine does 180s with my setup when brakes tapped. My set up is soft (red) springs up front and stiff (blue) in back. Soft tires in front and hard in back...Also tap the brakes before you turn, see if that satifes you. it might be the fact that you are going into the turn to hard and your cousin is simply slowing down...?.....just my 2 cents...
-Josh-
-Supra Chassis
-Stage 2 motor ( drag )
-Hard tires at rear soft up front
-stage 2 suspension ( soft up front and stiff rear )
-Wheel kit ("snow flakes")
- Tie rod
-Revell 240z model body ( custom mounted and painted blue with white hood )
-Light kit
-Custom graphics
- The most deadly soldier is the soldier without the instruction manual for his gun.-
Old 12-23-2003, 08:58 PM
springs
in the suspension set is it the springs or the bars that make the wheels turn
Old 12-23-2003, 09:08 PM
Chaos Fire Chaos Fire is offline
Try using a combination of brake and less throttle, I can do perfect turns with my RWD Supra...
Old 12-23-2003, 10:00 PM
RedRSX's Avatar
Subaru WRX STi
Re: springs
Well the servo makes the wheels turn...but i think you mean wich one makes it turn sharper. The springs allow more and less body roll, the tierods atcually make the wheel turn sharper...so the anwser is the tierods
Old 12-24-2003, 09:42 AM
skeeter149 skeeter149 is offline
on the remote there is a dial that says st. range make sure its at max that may help and wont cost nothing. sorry i tried
Old 12-31-2003, 07:26 AM
yeah that also can be the problem. But when you say you need "sharper" turns do you mean yours dosnt turn sharp at all and you turn in big circles or that you do turn sharp and just need sharper. Cause the control thing will work if thats the case
-Supra Chassis
- Tie rod
-Light kit
-Custom graphics
RCP Bank Turns & NEW SUPER MINI Picutres RCP-Tracks, Inc Tracks 11 01-06-2007 08:51 PM
Proper setup for tight Turns SohJai Bit Char-G / MicroSizers 14 03-28-2003 06:54 AM
Delayed turns to one side... shocon2k Bit Char-G / MicroSizers 2 12-22-2002 12:40 AM
Sharper steering solved Mr Freeze Bit Char-G / MicroSizers 9 12-10-2002 08:01 PM
Turns Left better than Turning Right? mechanist ZipZaps 1 10-08-2002 12:31 AM
