Old 12-22-2003, 03:43 PM
ceeyaracer ceeyaracer is offline
if u get a creast spinbrush motor and what
if u get a creast spinbrush motor do u need a different esc and also what would u need to make it work plz help
Old 12-22-2003, 09:35 PM
Lucid Dreams
you need to get the plastic gear off the brush (easy)
get a pinion either off an xmod motor (hard to do) or find a pinion layin around
then take the back plastic peice off of an xmod motor an replace the one on the spinbrush motor with it (the part of the motor with wires out the back) this also upgrades the brushes
then put it in an run it
Old 12-25-2003, 07:18 PM
rafucho rafucho is offline
Is there anyway I can pull the pinion without a pinion puller?
