Old 12-21-2003, 11:38 PM
RCDuggiedug RCDuggiedug is offline
Steering missing third wire
Hi all. Sorry I know that this issue is old but if someone could point out where a third wire would go, I'd like to try it and see if I can get my steering better. Thanks.
On the circuit board that is.
>What happens if I press this button? Formatting harddri....<
Old 12-23-2003, 01:30 AM
Sniper596's Avatar
Sniper596 Sniper596 is offline
I'm 1337 r/c'er :)
Damn another one, i'm on the same boat as you
Old 01-12-2004, 12:45 AM
cdog4w's Avatar
cdog4w cdog4w is offline
newbmaster
I just did the mod and I now have 7 steps in both directions. I have a white savanna with the three wires. On my board, the third wire (green) is soldered to a little chip marked "391" that doesn't exist on your board. The blue and yellow wires are also soldered to slightly different locations on the board. There are other differences as well. Hopefully someone can come up with a solution for your board too, or you can return it and try again.
I have a much higher resolution shot of this if you want (just email me).
EDIT: deleted old image (just a resized version of high res) and posted a cropped resized version (shows more detail for the same resolution).
My rides:
Old 01-12-2004, 12:53 AM
cdog4w's Avatar
newbmaster
Sorry for the double post. When I edited a second time to add the new image after I had deleted and saved, it wouldn't let me post with an image. So here it is, sorry for the trouble.
File Type: jpg ps resize of 2004-01-11 zzse internal 003.jpg (109.2 KB, 332 views)
My rides:
Old 01-12-2004, 10:05 PM
Thanks dog. I didn't think anyone was going to post a picture where the third wire went. I've had my car for about 3 months and I don't think the Shack would trade now. Who knows, someone might come up with something to help on the board I have. For now. I'm still having much fun with the ZZse and the Xmod.
Thanks again.
Doug
Old 01-13-2004, 10:44 AM
clxfiles clxfiles is offline
DuggieDug - Let us know if this helps out your steering becase I'm in the same boat as you. Funny thing is, I tried adding the green wire a few weeks ago off a pic someone else had sent me and the green wire was soldered to a contact right next to the yellow wire. When I put the wire on, it didn't help. I noticed that my friends green wire went to the same place cDog4w's goes but haven't had time to try it.
Just so people know, my 2-wire setup was in a yellow RX-7. I think that's the Enfini?!?
Old 01-13-2004, 11:10 AM
cdog4w's Avatar
newbmaster
Yea, the yellow rx7 is the Enfini.
My rides:
Old 01-14-2004, 09:08 PM
I just opened up my board and I don't have the joint in that location. I looked at the first pic posted by RCDuggieDug and it doesn't look like his board has it either.
Old 01-15-2004, 12:47 AM
Real Cars Suck
OH super! Now RS is doing PCB board revisions. Can you all give dates when you bought yours so we can get an idea of which one is the newer revision.
Mine was a three wire and bought mid December.
Old 01-15-2004, 01:37 AM
Well after the frustration I just had trying to fix the steering that car is now a "parts" car. maybe not even that since I wanted to see how hard it would be to get the transistors off in place of FETs. Now its transistorless... I'm leaving that up to the experts from now on. Those soder joints are way to small for me.
I bought this car in mid-Dec also, but I don't know how long it was sitting on the shelf (like I stated earlier it is an Enfini). My stang I bought at the same time has the 3-wire with y & b on the middle connect of the pot.
Here's a pic of what someone else gave me when I first tried adding the third wire manually. Oh what a tangled web we weave...
Old 01-15-2004, 02:12 AM
cdog4w's Avatar
newbmaster
i got one, returned it because it sucked and heard that some were ok and some not. the new one sucked too, so I went for this. purchashed 1/10/04.
My rides:
Old 01-15-2004, 06:50 AM
Got mine around the last of October. Since the board is not the same as the three wire version, haven't tried anything myself yet.
Old 01-15-2004, 06:31 PM
kanegs kanegs is offline
I bought my InitialD Mazda Savanna FC3S RX7 on New Years Eve 2003 and it's a two wire pcb.
BTW, what's that tiny motor next to servo for and is there a good lubricant for the gearing by the servo?
Jeff
Zip Zap SE Initial D White Mazda Savanna FC3S RX-7
XMODS RC34 Skyline AWD RS bearings
Old 01-15-2004, 08:19 PM
Real Cars Suck
That is the motor of the servo. You can lube the gears with some kind of r/c diff lube or other hobby lube. Though if you do, make sure the tiny crack in the wheel well that opens into the servo gears is taped off.
Old 01-17-2004, 06:31 AM
Nutjob GTO Nutjob GTO is offline
I'm gonna bump this one up, so...
Does anyone know which ones are most likely to be three-wire versions? I'd hate to get mine home and find it's only a two-wire setup.
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 12:16 PM
Problem With Steering Wire New_B Bit Char-G / MicroSizers 7 07-04-2003 02:20 AM
Bit TTTT Daisycutter TTTT 37 05-26-2003 02:46 PM
Wire for Steering Spring? ejaf ZipZaps 5 11-19-2002 04:14 PM
