Old 12-18-2003, 10:11 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
About the Spinbrushmotor
I was just thinking about something I HAVE NOT read about the spinbrush motors. if it only takes 1 or 2 at the most AA or AAA to run it (I have yet to get one), then wouldnt it overload the motor with 4 to 6 AAA's? This might be another reason it has so much torque. I was just thinking about this b/c no one has posted anything about this before.
Please Reply if you have something to add.
Old 12-18-2003, 10:13 PM
neurokinetik's Avatar
Mad Scientist
That's the reason the brushes are supposed to be changed when using that motor...
Old 12-18-2003, 10:15 PM
What happens if you dont change the brushes?
how hard is it to change the brushes?
what does changing the brushes do?
Old 12-19-2003, 12:22 AM
Lucid Dreams
i took an old stage one motor that i destroyed tryin to take the pinion off of an i took the whole back plastic part with the brushes and all an just stuck on the back of the spinbrush motor
so far so good
Old 12-19-2003, 08:58 AM
ok thanks.
