12-17-2003, 03:19 PM
One Heck of a Controller Mod coming up!
I'm currently workign on a design for a controller mod that I will be doing over the next 3-5 weeks. It will feature a seperate box with plugs for power, PC, 2x Joystick/Game pad. It will feature computer control (if I can get a copy of the software), with basically an integrated Nox Box. It will feature two 9 pin, or 15 pin game ports for a joystick or gamepad and A built in peak charger with charging base, switchable between single or dual cell. It MAY also have switchable frequencies, but that is only an idea right now, and may not be integrated into the first design. Any ideas on anything else to add to this? Also, does anybody have a copy of NOX's software trial or full version I can use?
12-17-2003, 03:24 PM
As soon as you put up the tutorial and pictures, I'm smelling Namuna moving this to Bit Science! Good luck on the project!
12-17-2003, 03:36 PM
Thanks! I'm still in the process of designing it and collecting parts, so it will still be at least a few weeks. I have a question though: Will charging the 150 mAh batteries at 2.8VDC 350 mA work for single cell and charging at 5.6VDC 350 mA for dual cell work? I'm basically using the electronics out of a Sunpak AA/AAA NICD/NIMH peak charger for the charger.
12-31-2003, 08:59 AM
Well, if this mod is going to happen, I need a copy of Nox's software. Does anybody have one?
02-18-2004, 04:29 PM
Well, This mod is pretty much on hold becuase Nox for some reason removed his software and will not let anybody else use it.
