Old 12-16-2003, 08:53 PM
Daazndood Daazndood is offline
bearings=sucky?
why do my bearings suck. i just put it in, and i did not see an amazing improvement like everyone else said. am i suppose to put vaseline all over it or something? what am i doing wrong. i cleaned it all and everything. alot of the grease is gone becuase it was stuck to the hair that i removed though. help me!
Old 12-17-2003, 04:24 PM
Bad Company's Avatar
Give it a little time. Let the bearings break in a little, they usually perform better after a little time.
Old 12-17-2003, 04:43 PM
neurokinetik's Avatar
Mad Scientist
Or if you have no patience, (like me) you can soak them in degreaser, rinse the degreaser out, then use a thin oil for lube.
Takes all of about 10 minutes to do.
Old 12-18-2003, 12:47 AM
breaking in eh? wow, so realistic. anyways, would holding it in the air and gassing it for 10 minutes be ok? or do i actually got to drive around.
Old 12-18-2003, 10:23 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
for the bearing on my skateboard, it took about and hour to break them in. I wouldnt recomend soaking them because ive seen MANY bearing destroyed that way.
