12-15-2003, 07:56 PM
("\(0.o)/") Rawr!
command logic lights problem
my friend gave me his lights for free, because the black and the yellow where pulled out off the white socket thingy, can anybody help me on how to put it back?
Xmod Parts Help
12-16-2003, 10:21 AM
Gerbil Racing
mine did the same thing....find an electrician......they MIGHT be able to fix it
its gonna be hard tho.....those connectors are very small
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
12-16-2003, 11:24 AM
I'm not a pyro, really.
if the metal piece came out too just figure out where it goes and pop it back in. IDK how to fix it if just the wire came out
NEVER UNDERESTIMATE THE POWER
12-16-2003, 11:58 AM
("\(0.o)/") Rawr!
its the wire that came out
Xmod Parts Help
12-17-2003, 11:39 PM
("\(0.o)/") Rawr!
uhhh I guess nobody here knows how to fix it.....
Xmod Parts Help
12-18-2003, 08:13 AM
strip the end and shove it back in there then heat shrink all 4 wires together
12-18-2003, 09:14 AM
("\(0.o)/") Rawr!
how do u heatshrink??
Xmod Parts Help
12-18-2003, 10:54 AM
RC Tinkerer
Heatshrink Tubing! Wonderfull Stuff!!!
Get it from RadioShack!
RS 6" Heat-Shrink Tubing Cat# 278-1627
You place the tubing over a wire or connection, then you apply heat. (I use a lighter) You move the heat source around and watch the tubing shrink! It creates a water tight seal, and also provides support to the connection to prevent it from seperating. I also use it for strain releaf when I have a wire comming out of a box.
12-18-2003, 07:04 PM
("\(0.o)/") Rawr!
cool I'll try it, the wire came out of the white thingy I manage to strip the wire so all i do is get the heat shrik wire and shove the stripped wire wit da heatshrink to the broken pulled out part and apply heat right? will it connect it? will a hair dryer work? or u mean HEAT like a match?
Xmod Parts Help
12-18-2003, 09:11 PM
RC Tinkerer
I do not know if a hair dryer will work, And I never tried a match. I have used a candle in place of a lighter, but that was because I had alot of wires to treat.
I think you will need 1 pice of heat shrink tubing to hold the wire inside the plug. Or maybe even replace the plug with something else that fits... I do not have the lights, so I cannot be more specfict.
12-18-2003, 09:51 PM
("\(0.o)/") Rawr!
.........  so how should I knoe.....If u haven't.........*mummbles.......*
Xmod Parts Help
