Old 10-05-2002, 10:33 PM
teamyoshi teamyoshi is offline
Send a message via AIM to teamyoshi
Question 2 speed?
What is the deal with the 2 speed option? what does it do? is it an electric boost or is it an actual gear? and do you need a special remote for it?
Old 10-06-2002, 12:45 AM
E)(pul$ioN E)(pul$ioN is offline
Founder of EaT RiCe Squad
Send a message via AIM to E)(pul$ioN
Yes you need a special remote for it... The special remote should have a small boost button that you can press. The two speed should be electronically controller, since there aren't extra gears... Hope this helps.
A student that doesn't like school.
Old 10-06-2002, 01:47 AM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
the picture attached is a 4 channel controller(with boost function) and a picture of a booster machine(it comes with clear skyline R34 body)
right now Tomy is offering 2 ready sets with boost functinos. its the new Z and the auto modelista set. they both have regular single channel controller. near the upper right side of the controller is the boost button.
u can run regular cars with the 4 channel controller in addition to the booster machines. so you just need one controller for all the cars you have. if you have more than one car
Old 10-06-2002, 04:29 AM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Originally posted by 323iT
...if you have more than one car
haha, i have one car! I'm the low budget R/Cer
Old 10-06-2002, 09:43 AM
NMT RACER NMT RACER is offline
Send a message via AIM to NMT RACER
where can you find that radio for sale? what advantage does the 2 speed car give?
can you run booster cars with normal radio and just be on 2nd speed 24/7?
thanx
Old 10-06-2002, 01:46 PM
thanx for the info all. i think i might go get one. inless it is too expesive...
Old 10-06-2002, 03:12 PM
r.c.dealer's Avatar
r.c.dealer r.c.dealer is offline
deviant bit char-g pro
thanx
You can't run booster cars on the regular transmitter as the signal is encoded differently. However you can run regular Bit char-G cars with the booster controller.
The advantages of the 2 speed is that you can let off the boost button to slow down for the turns while still providing power to the rear wheels. Another plus of the booster cars is that the circuit board allows the motor to draw more current in boost mode, which makes the cars faster than comparably equipped unboosted bit char-g's. On the downside of the booster transmitter is that its range is very limited. With an antenna mod, some people have been able to increase range in excess of 20+ feet!
Old 10-06-2002, 03:40 PM
r.c.dealer's Avatar
Ok?
Old 10-06-2002, 03:44 PM
Shagam Shagam is offline
How fair is it to race the booster cars though? I mean, my friends all have normal bits, and I was planning to get the auto modelista set...But would it be fair to race with the boost chasis? Is it only faster when the boost button is pressed? so like, I would be able to race fairly and normally as long as I don't use it...
Old 10-06-2002, 03:49 PM
Shacky Shacky is offline
My understanding of the boost function is that it runs regular speed with the boost button depressed and a lower speed when let go. There's a switch on the controller to run with it always depressed.
What's the advantage? You can slow down and maintain some power for turns to give you better control. This will help you beat opponents in turns since they will have to let go and coast into turns which is slower.
Old 10-06-2002, 08:00 PM
mr0072003 mr0072003 is offline
yeah i just got three booseter sets with in 3 days....and yes they help dramiticaly in the turns.....the onlyt thing that I have noticed is that the battery seems to doe easy.....but then again they are new,,,and it takes time to for them to run longer on charges....
Old 10-07-2002, 10:14 AM
e_lm_70 e_lm_70 is offline
Is the automodellista a booster machine ???
Old 10-07-2002, 03:56 PM
yes, it is
Old 10-07-2002, 04:54 PM
ulookin2 ulookin2 is offline
4 Band Remote
I have got the 4 band remote and a 35 Mhz booster and I also have the black celica regular bit, which is 35Mhz also, but the 4 band (booster) controller won't control the regular bit. I think it only controls the booster machine sets. I have the 45 Mhz supra and I will try to see if the booster controller works on it tonight after work and post a reply.
Old 10-08-2002, 01:08 AM
ulookin...you have to swicth your booster controller to mode a for it to runyour normal bits.....it located on the bottom of your controller.
SE 1/4 mile speed tests Steve ZipZaps SE 8 02-08-2006 02:04 PM
The Infinite Speed Potentiometer Mod (tm) actofgod Bit Science 46 09-16-2003 04:47 PM
speed speed speed ml22 Bit Char-G / MicroSizers 6 03-14-2003 12:27 AM
modified a body to fit Speed Racer Spec 1!! nojodash Epoch RC1/43 0 01-18-2003 09:16 AM
2.2 2 speed vs 2.6 1 speed eman1 Bit Char-G / MicroSizers 0 12-16-2002 08:34 PM
