Old 12-14-2003, 10:48 AM
cyrc's Avatar
cyrc cyrc is offline
i love lab rATS ther rad.
motor question???please help
i have a stock xmod and got stage 1 motors(not enough money for stage2)and i was wondering if it would be better to use topspeed motor because it has more torque than stage 2 motors or would it still be better to use roadrace
death is the number one killer in america ...dont become a statistic.
Old 12-14-2003, 10:52 AM
badboy727 badboy727 is offline
yea
it wold be better
Old 12-14-2003, 12:46 PM
neurokinetik's Avatar
Mad Scientist
It depends on the course you are running. A more open course with long straights may llow you to use the top speed motor, but acceleration will be poor compared to the road race.
Why not use some washers under your motor mounts and try using some of the intermediate ratios while using the 11T motor?
Old 12-14-2003, 02:44 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
by intermediate gears you mean using different spur gears with a pinon that wasnt meant for it right.
or you might try to change the timing. i dont know much about it though. i was in the process of learning and i forgot to turn off the soldering iron and know i have no access to any of my fathers tools
NEVER UNDERESTIMATE THE POWER
Old 12-14-2003, 04:33 PM
Mad Scientist
Yes. For example, if you pick up the washer kit at Radio Shack, you can put two washers under each of the motor mounts. Doing this gives enough clearance to run the 11 tooth pinion with the white idler gear, giving almost the same ratio as the 10 tooth motor with the yellow gear does. This is an easy thing to try, easier and less risky than trying to do the timing mod.
Old 12-16-2003, 11:38 AM
aperson's Avatar
thanks. that'll be a big help since i got the soldering iron taken away.
