Old 12-11-2003, 09:30 PM
Daazndood Daazndood is offline
Metal bearing=dirty easily too?
hi all. i wanted to know was if these metal bearing get hair and nasty little things stuck in it easily. with the plastic yellow bearing i have right now, evertime i take off my wheel, its covered in nasty black stuff. i dont think metal bearings with nasty black stuff will help alot.
basically, im on a 20 dollor xmods mod budget. since bearings cost that much, i was wondering if i should get them. or should i get suspension and tires instead?
Old 12-11-2003, 10:55 PM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
The bearings really are worht it...it makes your car much quieter and you will actually feel the difference in how the car runs. As for the balck stuff. I had that happen at first to...but the reason for that , i think, is that the factory put a lubricating grease on and in those yelloe plastic bushings. When you get the bearings, i would suggest you de-grease them, then lubricate them with powdered graphite. I got mine at home depot for like $2. Oce you de-grease them and put the powdered graphite in them...you hardly ever get that black crap in your bearings. I also really like the fact that your car is much quieter and just sounds super smooth
Old 12-12-2003, 11:09 AM
Se7en Se7en is offline
I'll have to go look for this powedered graphite. I have cats in the house and amount of cat hair that accumulates in the wheels and bearings is rediculous.
White Supra
Stage 10 motor 9 tooth
6 cell Rayovac IC-3
AWD
3 deg toe in
Yellow springs front, Blue springs back
working on yellow/black VW GTI body
Old 12-12-2003, 08:07 PM
Shiporu's Avatar
Shiporu Shiporu is offline
I make great sandwiches
Send a message via AIM to Shiporu Send a message via Yahoo to Shiporu
bearings
Se7en,
I just cleaned my metal bearings....oh!! you should of seen the @@@@ in there... but no cats in my house. but since i race out side, lots'o hair and stuff...mostly dust. But by all means get the bearings.... degrease 'em and you good to go...
My Xmod:
now has Tiny Rc parts and schools everyone here!!!
Old 12-12-2003, 08:52 PM
does it still run good with all the gunk in it?
and has anybody ran plastic vs metal bearing tests? i would like to know the results
Old 12-13-2003, 04:52 AM
Shiporu's Avatar
uh, no. gunk make car slow and junk. slow car= scrap.
As far as the plasic bushing vs. Metal bearing, I blew my freind away. same motor and all....but i had the metal bearings. but as far as an actual test, nope. have not done that. I think I should do that though, would settle a lot of arguments...
My Xmod:
Metal Cup Joints For Hella Cheap RacinSkillZ101 XMODS Mods and Projects 33 10-12-2006 01:17 PM
Metal Bearing / Wide Track Bearing Combo Pack - $20.00 Shipped!! RSXSpeedDemon XMODS Parts and Hop-Ups 0 07-13-2004 10:59 PM
Metal ball bearings hoopsta1423 XMODS Mods and Projects 7 12-29-2003 01:17 AM
Blue metal flake Celica(How to) MythosGR Bit Char-G Gallery 7 03-07-2003 11:24 AM
Metal tracks T_T_52 Combat Digi Q 3 01-10-2003 04:46 PM
