Old 12-11-2003, 04:06 PM
Bash_N_Thrash Bash_N_Thrash is offline
Probs right out of the box
I just bought an Xmod about an hour ago. I was putting it together and studying it carefully. I got as far as putting on the wheels.
First problem is the Tires. The little plastic thing they come in was distorted and left impressions in the tires, none are round or smooth.
Second problem is the wheels are very loose and theres lots of slop in them. Tightening the nuts as tight as I dared helped but there is still about 1-1.5mm of slop.
Third problem is the front wheels. They contact the knuckles, and make alot of noise while spinning. Not to mention a potential loss in speed.
Fourth problem is the stance of the car. The left front wheel is about .75mm off the ground just sitting on a flat surface. If I push it down the right rear tire comes of the ground. It just kind of teters on the left rear and right front tires.
I love fixing these things myself, but should I take it back and get a better one to start with? Or will I find this on just about any I get. Three of us at my work bought them all at the same time and place. One guy has his put together and it seems much better than mine. The other guy hasnt opened his yet. Any advise?
Old 12-11-2003, 04:14 PM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Send a message via AIM to aero528
return it. mine was never like that.
--Chris
Aka...aero528
Old 12-11-2003, 05:11 PM
SonicKuz SonicKuz is offline
Send a message via AIM to SonicKuz Send a message via Yahoo to SonicKuz
return it. they have loose quality standards. mine didn't run right when i got it.
What goat?
Old 12-11-2003, 05:25 PM
Bad Company's Avatar
The wheel nuts not going on all the way is pretty common. It is due to the fact that the nuts are closed ended and don't allow the axle threads to stick thru. You can drill them out before installing to cure that.
As for the wheels haveing flat spots from the packaging, if they don't return to original shape after being out a while, then return it.
If yoiu are having problems with the frront wheels rubbing though, you might as well return it for another.
Old 12-11-2003, 06:33 PM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
see that is onething xmods lack severly. It is consistency between each car...some are perfect and some (like the one you got) are absolute crap...just keep returning till you get a good one...i got a good one and i love it
Old 12-12-2003, 01:21 PM
Well I took it back and got another one. It seems much better. Thanks for the advise.
Old 12-12-2003, 03:20 PM
Skurge420's Avatar
Skurge420 Skurge420 is offline
Gerbil Racing
Send a message via AIM to Skurge420
ya ....some are good some aren't.......i've gotten 3 bad ones so far
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
box full of junk isk8blind For Sale/Trade 0 08-10-2008 06:26 PM
Project: Dnano Box simpleskin Kyosho dNaNo 1 07-25-2008 06:37 PM
Modded.... tool box? Rez XMODS Mods and Projects 3 03-28-2006 10:51 PM
SP battery box cdog4w ABC DTM SP 3 06-10-2004 09:45 AM
skyline probs ruslick2g4 XMODS 8 12-06-2003 06:01 PM
