Old 12-11-2003, 04:52 AM
miller miller is offline
Steering issues?
My car turns to the left just fine but I seem to get major oversteer on right turns. A couple of my friends experience this too. Does anybody else have this issue and what can be done to fix it?
Old 12-11-2003, 01:20 PM
Btman Btman is offline
First, make sure there isn't any lint, hair, carpet fiber or similar material stuck between one of the wheels. If not, make sure both front wheels spin with the same amount of freedom. If one wheel has significantly more friction than the other, that will affect handling. One wheel may be tighter than the other on the opposite side. If the car is still stock rear wheel drive, make sure the differential is working smoothly. You should be able to see the rear wheels turn in opposite directions if you turn one by hand without any feel of gear binding. If you are running on a surface with poor traction and are using the stock tires and springs, you may want to try softer rear springs and/ or tires from the upgrade kits.
Try each of the above tips one at a time to see if it helps correct the problem.
So yea I Just went out to buy one... steering issues LancerEvoX ZipZaps SE 7 01-03-2006 02:23 PM
Steering Issues 1SloSupra XMODS 0 08-24-2005 04:52 PM
Steering Issues Jeremy386 Bit Char-G / MicroSizers 3 10-25-2002 09:55 PM
