Old 12-08-2003, 08:01 PM
RedRSX's Avatar
RedRSX RedRSX is offline
Subaru WRX STi
Exclamation Make your AWD XMOD haul ace!!
Hey, I just found out that if you have AWD and switch the front and rear differentials. Have the ball diff. in front, and the LS in back...then for some reason it goes super fast. I raced my friend who has the same upgrades as i do and it isn't even a contest...i just own him in every aspect!! I definetley recommend doing it
Old 12-08-2003, 08:10 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
hmmmm.....ill have to try that next time i change the springs......or when ever the next time that i go "under the hood" is........but im still really happy with the AWD. as it is......i wish there was somone around here i know that has an xmod......i need to race..........
-Andres
Old 12-08-2003, 08:38 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
hey dat waz my idea......
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 12-08-2003, 08:53 PM
viperkilla's Avatar
Acura RSX
Man, I know how you feel. The only r/c's around here are either zip zaps or microsizers. I guess you could race a ZZ and an XMOD but that wouldn't be very fair.
Old 12-08-2003, 09:01 PM
FrozenKamikaze's Avatar
FrozenKamikaze FrozenKamikaze is offline
Don't point at Me!
Just do what i did tell all your friends that you think might be somewhat interested in RC to go buy a Xmod and you'll all start racing together.I told 3 of my friends to go buy some Xmod's and i let Anthony use my black civic for a little bit and he seriousely wanted to buy one after that and then i told him about all the upgrades and stuff and he just got hooked.....man i should work at RS
Last time we wen't rollerblading around town i stuck my Xmod in the starterkit case and rtook it all over town takin it out at every spot we hit
So just spread the word.
Black Honda Civic coup
Rechargable batt upgrade.
Command Logic light kit.
Stage2 Drift.
Tire upgrade.
Steering & Suspension upgrade.
1.5 steering rod.
Yellow springs all the way around.
Soon to come: Body kit
Old 12-08-2003, 10:09 PM
RedRSX's Avatar
Subaru WRX STi
Yea...trust me this really helps your acceleration and cornering...don't ask me why, it just does. Give it a try...it can't hurt
Old 12-08-2003, 10:17 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i'll try to explain. lets assume that the tires have perfect traction so there's no wheelspin. with the regular diff (gear type) power is instantly transfered to the wheels thus accelerating away with full power. the ball diff on the other hand, kind of acts as a slipper clutch. if you've looked inside the ball diff (i can post pics of both ball diff and gear diff both taken apart if requested) two metal rings connected to the driveshafts press against 5 ball bearings in the middle. metal to metal isn't the best material for surfaces that need to grip. thus, when full throttle is applied, the ball bearings, which are carried in the middle on the main housing, will be overcome with too much torque and slip on the two metal rings. with the tires fictional perfect traction, no power is transferred. higher quality ball diffs will allow some adjustability to loosen and tighten it. this will make turning easier/harder and tightening it will give the ball bearings a higher threshold before it slips.
basically, the xmod ball diff will limit the two wheels connected to it from spinning at too different of a speed making it harder to turn. it tries to turn both wheels at the same speed so that if one wheel loses traction, the other still has power to keep it moving.
this is opposite of the gear diff where it's great at turning but when one wheel slips, power is lost to the spinning wheel
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-08-2003, 11:27 PM
shaolin_racer shaolin_racer is offline
So it will act more like a 1 or 1.5 way limitted slip?
Old 12-09-2003, 09:26 AM
TypeZer0's Avatar
0reZepyT
it acts as both a 1.5 way lsd and a clutch. ever redline a car and drop the clutch and the clutch can't handle it and the car doesnt' really move but you smell a burning? same thign with these except they don't burn, they're not tight enough to handle teh full throttle of even a stock xmod
Anyone make an Escalade for an xmod? Morphes XMODS Gallery 13 02-15-2004 10:49 PM
Can you make a Xmod sit higher? FrozenKamikaze XMODS 25 12-02-2003 09:13 PM
an idea on how to make your xmod do real wheelies!!! cyrc XMODS 9 11-23-2003 02:35 PM
I Finally got a xmod!! So what do i need to do to make it last longer and go faster Biohazard87 XMODS 2 11-14-2003 09:19 PM
How to make my XMOD go straight viperkilla XMODS 5 10-24-2003 09:33 PM
