12-07-2003, 12:33 AM
Gerbil Racing
stage 2 9 tooth vs. 8 tooth
i have the 8 tooth stage 2 in my supra and the 9 tooth in the skyline
now the 9 tooth should have more top end than the 8 but in my case the 8 tooth is quicker off the line(it should be) but it also has more top end
both have the same setup
yellow springs in back
soft slicks
same gear in the rear end
bearings in both
any ideas?
Mini Cooper Mini-Z
AE86 Corolla GT-S Micro RS4
12-07-2003, 01:42 AM
Mad Scientist
Try switching the motors between cars... it is possible that one car is just built a little better than the other, has less drivetrain loss, etc. It could also be that the motor with the 9 tooth is not broken in as well, wasn't built as well, etc. These motors in general aren't the most consistent of performers.
12-07-2003, 02:51 AM
more teeth=faster acceleration, less top speed.
less teeth=slower acceleration, more top speed.
12-07-2003, 02:55 AM
hm, you should preface that statement by specifying on the that you're referring to the teeth on the cone gear. If you are referring to the pinion, you have it reversed,
8 tooth will give you great acceleration, but no top end
while
12 tooth will give you lack luster accel, but great top end
sherif
12-07-2003, 03:55 AM
 sorry, i should read post more carefully before i reply.
12-10-2003, 09:14 AM
Skurge420:
You are right that the 9 tooth has more top end but only if it has enough torq to reach that top end.
The reason you are seing the 8 tooth having more top end is that even though it's max possible is less, is has the torq to reach that speed while the torq limited 9 tooth can't even get to that speed let alone it's higher top speed.
12-11-2003, 06:14 PM
Gerbil Racing
makes sense now.......i think it was just that sar that was messed up....
i blew out the rear end in the slower car......got a new one......now its how its supposed to be
Mini Cooper Mini-Z
