Old 12-05-2003, 02:41 PM
neurokinetik's Avatar
Mad Scientist
Misaligned left rear suspension arm
Something I noticed when assembling my blurple Civic last night...
As I was assembling the rear end, installing the ball bearings, I was paying close attention to reducing drivetrain friction wherever possible. I trimmed flash from the dogbone and cups, etc. Up until I installed the left rear suspension arm (with the dogbone installed) the assembly was rotating very freely, as it should. Once I installed the arm, I noticed that there was a problem. Rotating the axle on the right side would spin the diff, but not the left axle. Without the idler gear in place, it should all rotate as a unit. Taking a closer look, I noticed that the axle was not sticking straight out from the suspension arm, but was pointed forward slightly. This was causing the left side to bind up slightly. At first, I thought the bearings were just not seated properly, but they were actually fine. Fortunately, between three car kits and two AWD kits, I was able to find one suspension arm that did not exhibit this issue. Once replaced with a good part, the whole thing would just spin and spin, no binding at all.
So, for those of you who are wondering why your car is slower than your friend's, even though you have the same mods, this is one place to look.
Old 12-05-2003, 09:39 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
both of my left side suspension arms are F'ed up the front one the hole is too big and the left rear is turned in like yours. i didnt pose too big of a problem just that it would turn better one way then the other.
NEVER UNDERESTIMATE THE POWER
Front suspension in rear T Man XMODS Mods and Projects 14 06-27-2005 05:35 PM
Rear suspension mod BC I need your help on this one!! Kubrel XMODS Mods and Projects 4 01-13-2004 02:24 PM
Rear suspension upgrade idea... neurokinetik XMODS Mods and Projects 2 12-29-2003 02:24 PM
Rear suspension on a bit? chelboed Bit Char-G Mods and Projects 28 04-13-2003 09:51 AM
