Old 12-04-2003, 01:21 AM
yz85rider yz85rider is offline
Spring kit Upgrade?
Do these really help handling at all. Or what does affect ad are they worth 8 bucks or whatever?
Old 12-04-2003, 07:07 AM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
YES!!! i also get the AWD kit and that too improved handeling greatly.......i reconmend getting them bothe at the same time so you can insall them at the same time.....
-Andres
Old 12-04-2003, 09:07 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
yes it really does make a big difference in handling. and with it you can do alot more than with the stock suspension.
NEVER UNDERESTIMATE THE POWER
Old 12-04-2003, 03:15 PM
SonicKuz SonicKuz is offline
Send a message via AIM to SonicKuz Send a message via Yahoo to SonicKuz
You can change your spring rates, though you could just buy the springs for a mini-z and fit them on. You also get new shocks with steel pins instead of plastic. They spring more smoothly, but I feel they rebound quicker too. There is a special characteristic to plastic friction shocks, and I'm not going to knock them since they don't bind. IMO I like the new shocks but don't find that they are functionally superior.
My mini-z's stock king pins would bind, making the stainless steel king pin upgrade worthy. IMO you don't need the shocks, and if you want to change your spring rate you can buy just springs somewhere else, or try pulling some out of a pen.
What goat?
Old 12-04-2003, 03:22 PM
viperkilla's Avatar
Acura RSX
How wide is your turning radius? Mine seems to be fairly large.
Old 12-04-2003, 05:40 PM
miniDRIFTER's Avatar
miniDRIFTER miniDRIFTER is offline
modSquad Member.
Send a message via AIM to miniDRIFTER
what exactly is the spring rate? can someone please explain what spring rate means?
White '97 Toyota Supra
Mild front, wild sides, stock back
Stage II motors
Hard suspension
Black painted Enkei wheels
Command Logic lights (Courtesy of http://www.xmodrc.com)
In the process: XMOD™ Dynamometer (DYNO)
Old 12-04-2003, 07:54 PM
The way I think of spring rate is the force and speed of the springs in action, and damping as how long it takes to return to normal.
What goat?
Old 12-04-2003, 08:08 PM
Just found out that the mini z springs may be too short, unless you use the longer type.
What goat?
Old 12-04-2003, 08:31 PM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
i heard that with the awd it makes the turning radius bigger. is that true? and also does it make you less likely to drift b/c i want to drift
Old 12-05-2003, 10:52 PM
aperson's Avatar
1. only bigger if you install something wrong or dont lube the differential
2. it makes it easier to drift
Old 12-05-2003, 10:57 PM
is that because you get even more grip on the front tires?
Old 12-08-2003, 04:23 PM
my turning radius is significantly tighter than it was stock........and now i just need to get a motor upgrade.....stage 1 or stage 2?..................
-Andres
Old 12-08-2003, 04:28 PM
if you want torgue-stage 1
if you want speed-stage2
if you want a lot of torque and good speed-crest spin brush
Old 12-08-2003, 09:38 PM
FrozenKamikaze's Avatar
FrozenKamikaze FrozenKamikaze is offline
Don't point at Me!
A toothbrush motor... dude that's really Ghetto......
Black Honda Civic coup
Rechargable batt upgrade.
Command Logic light kit.
Stage2 Drift.
Tire upgrade.
Steering & Suspension upgrade.
1.5 steering rod.
Yellow springs all the way around.
Soon to come: Body kit
Old 12-08-2003, 11:03 PM
ALOT of people are using them and from what ive heard they have so much torque that you have to glue the back wheels on or they wil fly off.
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 08:43 PM
question about the suspension and steering upgrade kit LightFetish XMODS 1 01-30-2006 12:48 PM
I got the new upgrade kit. Zephyranthes ZipZaps 6 10-01-2005 09:56 PM
XH XMOD Wire Upgrade Kit NOW TAKING ORDERS XAnubis XMODS Parts and Hop-Ups 8 12-12-2003 03:09 AM
German Import Upgrade kit airline2 ZipZaps 11 12-24-2002 11:06 AM
