Old 12-02-2003, 10:16 PM
crazydave's Avatar
Garage Rocker
Anyone know what pitch Xmods pinion is?
Is it 48 pitch like the Mini-Z?
Will a pinion like this work?
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=5871
Old 12-03-2003, 09:28 AM
hotrod29728's Avatar
no you cannot use that gear besides if you add another 3 or 4 dollars you can get a stage two kits from RS
Current XMods:
Black Skyline: Stage II Motor
Current Microsizers:
Current Zip Zaps:
Black 68 Camaro SS
Red 25th Anniversary Camaro
Black Chevelle SS SE
Mazda RX-7 SE
Mazda RX-7 SE
Silver Pontiac Trans Am
Orange Mustang SE
Old 12-03-2003, 02:41 PM
stl2ner stl2ner is offline
they mini z pinions are too long and are smaller, I have a twelve tooth mini z gear and it is only as big as my nine tooth pinion.
Old 12-03-2003, 05:41 PM
crazydave's Avatar
Garage Rocker
Yeah I have the stage 2 set. I'm thinkin for trying other motors, and I don't want to end up messing things up trying to yanking those brass pinions off over and over.
Ok so it's not 48 pitch like the mini-z, does anyone know if it's 32 pitch or is it some oddball pitch then?
...and thanks for any info you might have.
Old 12-03-2003, 06:58 PM
more than likely its a 32 but it could be an oddbal and be like a 20 somethin..........just my 2cents worth
Current XMods:
Current Zip Zaps:
Black 68 Camaro SS
Mazda RX-7 SE
Mazda RX-7 SE
Orange Mustang SE
Old 12-08-2003, 09:31 AM
crazydave's Avatar
Garage Rocker
I think I found a possible replacement pinion.
http://www2.towerhobbies.com/cgi-bin...?&I=LXEMZ9&P=7
I'll probably order a couple to check out.
Old 12-08-2003, 09:50 AM
neurokinetik's Avatar
Mad Scientist
Seems a bit expensive. For that much, I'd stick with sacrificing stage 1 motors. I'd want to see one that isn't press fitted.
Old 12-09-2003, 10:04 PM
Mad Scientist
I saw 42 pitch pinions available for the Micro RS4. It might be what we need, though they were $8.00 each, so I'm hesitant to try one. They are titanium, and not press-fitted.
http://www.hobbyetc.com/cgi-bin/cata...at=187&man=all
Old 12-10-2003, 12:06 AM
Cyfiawnder Cyfiawnder is offline
I use an 11 tooth 48 Pitch Slot car pinion with the RED drag Drive gear in my XMOD with no problem. Pinion cost $2 US from "Trains and Lanes" it's a hobby store. But I'm sure any Slot car type place will have these gears. The Pinion puller cost more at $9
SEE MY POST ABOUT THE NURELCO BEARD SHAVER MOTOR
Loud doesn't = fast.
Import doesn't = quality.
Chrome Doesn't = performance gains
Clear Tailights just make you easier to spot.
My 4 cylinder has 210 Natural aspirated HP is only 2.3 li, and is 15 years old, and it was built right here in the good ol' USA.
Old 12-10-2003, 12:50 PM
Mad Scientist
But is it actually the same as the XMods pinion, or is it just "close enough." Because "close enough" doesn't cut it when you are trying to reduce drivetrain losses to the bare minimum.
Can you post a pic next to the stock 11 tooth pinion for comparison?
Old 12-10-2003, 02:18 PM
Sorry I can't post pics, no Digital camera. only difference I see between the stage 2 11 tooth and the 11 tooth I bought from a hobby store, is the Stage 2 is longer by at least 1/16" and the stage 2 pinion is brass. The one I have is steel. I do have a 12 tooth brass pinion but it's a little chewed up, and I didn't want to chance it....
Old 12-14-2003, 03:03 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
found this page: http://www.schafergear.com/chicagogear/gear_info.html
there's a formula to determine the diametrical pitch.
P = (N + 2) / OD where P = pitch, N = number of teeth, OD = outer diameter in inches.
using my stock motor, i've found this:
N = 8, OD = 6 mm = 0.2362 inches
P = (8 + 2) / 0.2362 = 42.337002540220152413209144792549
or 42 pitch.
now all we need are some cheap non press fit 42 pitch pinions
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 12-14-2003, 03:20 PM
Mad Scientist
I saw that page, or one like it... that's how I came to the conclusion that XMods use around 40 pitch.
I've ordered a couple of the ridiculously expensive titanium 42 pitch pinions. If they work, it also opens up the possibilities of taller gear ratios, as they are available in 13, 14, and 15 tooth, as well as 10 and 11.
Old 12-14-2003, 04:24 PM
TypeZer0's Avatar
0reZepyT
i looked through all of towerhobbie's pinions and found no 42 pitch pinion and even if they did, it wasn't specified in many of the pinions i saw that looked like it would work
Pinion Pitch dero XMODS Parts and Hop-Ups 1 12-31-2005 07:54 AM
Mini-Z VS. XMODS jerm781 XMODS 16 10-19-2003 09:17 AM
Xmods Announcement cj1267 XMODS 2 10-16-2003 04:34 PM
