when i turn right i have a wide turn and when i turn left i have a tight turn....why? i also noticed that when you turn the controller on and turn the wheels they dont turn to there full potential. use your hands to turn the wheels and youll see they go much farther...
Steering trim is to correct straight line tracking. If your car is constantly pulling to one side or the other you can adjust the steering trim to compensate.
To solve your problem 1) Check for debri in the wheels and knuckles. 2) Are your batteries fully charged? That's the first thing to go when your batteries are low. 3) Check to make sure your controller is set on max st. range. 4) Grab the wheels with the car turned off and fully turn them a few times. This will help loosen up stiff knuckles.
