11-30-2003, 08:01 PM
Acura RSX
Antennea?
Have you guys noticed that the antennea that is on the chassis is very fragile and breaks easily? Has anyone broken their antennea and soldered it to the little piece of metal? If so how hard was it and does it still have the same amount of range before it broke?
11-30-2003, 08:04 PM
Put Custom User Text Here
did you break yours?
11-30-2003, 08:32 PM
sleeper mall civic
how did u break it , i got tired of the studering so i took the stock antena off and put on a longer one (over 100ft in range)
carbonfiber black civic, body kit with mixed wild and mild,white supra rims cf hood, lights 1' antena evo front bumper for racing and some shows stage 2 motors,hard treads in back with hard springs and soft slicks and soft springs up front ,running drift for now and 3rd chasie
douglascounty!!!
11-30-2003, 08:35 PM
i think i have broken that connection on every xmod i have
as for how hard it is to reconnect... not hard at all ,just solder it back to the tab
reconnecting imo has not made the range any better or worse
btw...are u talkin bout the actual antenna or u talkin bout the wire and tab from the pcb? cause im talkin bout the wire and tab
never jump in the water...use a ladder
11-30-2003, 08:52 PM
the wire from the tab on my 2 x-modss both fell off so i soldered them on.
12-01-2003, 08:25 AM
I'm not a pyro, really.
if the wire falls off, make sure that it doesnt touch the motor or it will fry a resistor and your range will be really screwed up.
NEVER UNDERESTIMATE THE POWER
12-01-2003, 10:07 AM
....as it says in the owner's manual- get into the habit of removing the batteries from the car when not in use
and if it falls off when running and touches something (motor, batts,ect....ya then your screwed
12-01-2003, 03:14 PM
i didnt know that. thanks for that bit of info.
12-01-2003, 03:20 PM
Acura RSX
I am talking about the wire and tab. I haven't broken it yet, but I have on my Skyline XMOD.
12-01-2003, 03:23 PM
like my dog??
if you breack it then souder it back and put hot glue on the sauter and part of the wire. this will help keep it on better. make sure not to put hot glue in the hole!
--Chris
Aka...aero528
12-01-2003, 05:26 PM
thanks for the info. RS really needs to get better solder or something.
12-01-2003, 05:28 PM
sleeper mall civic
they need stronger wire and where u dont have to remove the battery pack to change out something
douglascounty!!!
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Antenna help
lckyrocket |
XMODS Mods and Projects |
3 |
12-30-2003 12:33 PM |
smoking civic
kasper01001 |
XMODS |
13 |
12-20-2003 08:13 AM |
