11-30-2003, 05:50 PM
The One Punisher
weight
my xmod is seems 2 heavy...wat suggestions do u ppl have 4 cutting out some of the wieght. i need 2 lighten the load but im not sure wat mods i can do 2 it? Also, should i take of body parts like spoilers etc.
post ur ideas about how 2 make ur xmod lighter. thxs
11-30-2003, 05:53 PM
Acura RSX
Yea use the stock body kit. The mild and wild body kits weight it down. You could uninstall AWD if you have it since it adds more weight to the car.
12-01-2003, 01:35 AM
DDR PIMP
Try taking out those beige-colored plates and replacing them with thinner, lighter plastic.
12-01-2003, 08:19 AM
I'm not a pyro, really.
if you have AWD installed use the top plates that held the front end together instead of the plastic top plate that comes with the car.
NEVER UNDERESTIMATE THE POWER
12-01-2003, 12:30 PM
Sleeper Supra
i took a dremmel and ground the corners off all the "sharp" bends+ angles
12-01-2003, 01:53 PM
PPG Co-Owner
take a dremel and shave everything in the inside of the body, and drill lots of holes in lots of the stuff on the chassis e.g. battery clips, underparts of the chassis, etc.
12-01-2003, 09:07 PM
Just take off the body, that'll make it hella light.
12-01-2003, 09:16 PM
sleeper mall civic
i took off the thing where u screw the antena in and i sanded down the body and its kinda light now that the body is thiner im gona replace the other tan thing in front with a peice of plastic
carbonfiber black civic, body kit with mixed wild and mild,white supra rims cf hood, lights 1' antena evo front bumper for racing and some shows stage 2 motors,hard treads in back with hard springs and soft slicks and soft springs up front ,running drift for now and 3rd chasie
douglascounty!!!
12-01-2003, 09:22 PM
you can take the front over off that would cover the awd gears
take the battery clips off and whatever else you can find to replace i guess
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Body Weight
Steve |
ZipZaps Mods and Projects |
3 |
02-19-2006 08:56 AM |
Weight
Jtskty |
Bit Char-G Mods and Projects |
10 |
12-14-2003 02:34 AM |
Initial D is addictive
zombiebaby |
Bit Char-G / MicroSizers |
96 |
07-20-2003 01:31 AM |
Weight distribution
maxximum attack |
6 |
07-19-2003 08:18 PM |
Antenna Weight mod
DisfourDan |
Wild Char-G |
6 |
01-14-2003 09:02 AM |
