11-28-2003, 01:19 AM
Subaru WRX STi
Whats so good about locking your differentials??
Hey i read a thread about locking your differentials...now i know that 4-wheeling SUV's want that but why do you want that on your car??? Thanks
11-28-2003, 08:52 AM
2Fast4U
Locking a differential will change handling. A locked rear diff will allow the car to turn really sharp. A locked front diff will allow the car to pull hard (accelerate) in the turns and carry a lot of speed in the bigger sweeping turns. I would personally just leave these parts alone, but if you run on a track with a lot of tight turns, try locking the rear. If you run on a track with large sweeping turns you might try locking the front diff. If you only drag race, try locking both.
11-28-2003, 09:06 AM
Cheese Ninja
I locked my rear stock differential, and you can easily tell the difference. It has more even acceleration and, uh, stuff.
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
11-28-2003, 12:36 PM
SUPERBEAST
ummm how do lock a differential, and does it take speed away.
hello
11-28-2003, 12:41 PM
Subaru WRX STi
What would happen if i locked both differentials...would i handle better and accelrate batter??
11-28-2003, 01:42 PM
I'm not a pyro, really.
if you lock just one differential in an AWD car with 2 gear differentials it will lock both differentials because there is no 3rd diff in the middle of the two. to lock them you could put superglue in them or put a very thick oil or something in.
NEVER UNDERESTIMATE THE POWER
11-28-2003, 01:51 PM
SUPERBEAST
instead of superglue would a hot glue gun work.
hello
11-28-2003, 02:41 PM
Poopie monster
I used silly putty
wat
11-28-2003, 04:03 PM
Zhuge Liang - My Idol
where exactly are the front and rear differentials?
11-28-2003, 04:15 PM
The diff is the red circle that connects the motor to the axle. It has gears on it and is on the axel. There is one on the back and front. Um. If it is stock then it would only have it on the back and it would be white. Thats all i can explain about it now.
Xmods Civic:
Custom 36t 28gauge ball bearing neo mag motor, Soft treaded tires, 5 spoke rims, AWD, Hard springs in the back soft in the front, lowered BC's way, 6 cell with I-C3s, and one awsome drifter/driver/racer.
11-28-2003, 04:40 PM
so do i just put the grease or whatever i use in the hole on both sides?
11-28-2003, 05:59 PM
SUPERBEAST
ok i hot glued it and its accel sucks, it barly moves, and the reverse doesent work. i can pull the glue out but can someone post pics on how to do it.
hello
11-29-2003, 01:54 PM
heat, its easier to take it apart and superglue the gears together. i wouldn't reccomend doing this if you dont have AWD so you will have an extra differential if you screw one up. and you cant lock the Ball Differential/ Limited Slip Differential
11-29-2003, 02:06 PM
custom title
dont use superglue. You can use some thick grease to semi lock the diff. Or you can use something like silly putty that is removeable.
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
11-29-2003, 04:15 PM
anyone wanna get me a screenshot :P i have 2 differentials so that's not my concern. i just dunno where to put the grease and what not.
