11-28-2003, 12:55 AM
5 or 6 cells???
Ok I going to radioshack tommarow, gonna get sum rechargables to replace the 1.5v non-rechargable battiries i been using up lol
I was gonna get a AAA holder to while I was there with teh rechargables, should I get a single or double holder?
I dont know if I should go with 5 or 6 cells, I plan on making a drifting X Mod out of my Supra, which one would be the best to go with?
Setup:
97 Supra White
Soon To Come:
6th Cell (just have to wire it up)
Green Underglow (just have to wire it up)
11-28-2003, 12:12 PM
anyone know?
would like sum input b4 i go there today n buy it, i thinkin or 5 cells just to be on the safe side with the who thing...
Setup:
97 Supra White
Soon To Come:
11-28-2003, 03:19 PM
Got 4.2 King? I do : )
i havent done it yet but i hear that 6 cells works fine. only problem is the lights wont work with the extra cells for some reason
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
11-28-2003, 03:25 PM
Yeah I think I just gonna go 5 cells becouse I dont know were I can fit a 6th lol if I go 5 I can always add a extra later i guess
Setup:
97 Supra White
Soon To Come:
11-28-2003, 03:28 PM
I think that the 6 cell would work the best. You really need tourqe but speed would be good too. I am also working on a Drift car. I'm going to put on it a six cell, SPB motor, high speed gearing, all wheel drive, hard slick tires (do they have those?), hard springs in back and soft at the front, 4.5 degree tierod, and i have recently heard that the wings actually make a diffrence with the handling so im going to try and get a custom one from www.tinyimports.com . Its is 10-13 buxs so it is a kinda expensive but im only going to need one so I will most likely sell the rest.
Xmods Civic:
Custom 36t 28gauge ball bearing neo mag motor, Soft treaded tires, 5 spoke rims, AWD, Hard springs in the back soft in the front, lowered BC's way, 6 cell with I-C3s, and one awsome drifter/driver/racer.
11-28-2003, 10:16 PM
they didnt have a single batterie holder so i got a double
i going with 6 cells, but i cant fit it under the hood!!!!
sum1 hlp i need pix of how u guys got it to fit, as soon as i mount it i gonna work on the underglow
Setup:
97 Supra White
Soon To Come:
11-29-2003, 12:04 AM
0reZepyT
at 1/24 scale you're not gonna notice a difference with a custom wing, not much anyway. maybe if it had a large surface area then i'd look into it but anythign small i wouldnt' really count on it. my 6 cells work fine with my command lights btw
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
11-29-2003, 12:32 AM
does it work much faster?
I just got my 6 cell setup but I cant fit it, u got any pix?
I got a Supra n it cant fit under..... but then again i got the command lights i will try taking those out tommarow to fit the 2 extra cells
Setup:
97 Supra White
Soon To Come:
11-29-2003, 12:38 PM
But if u add more lights to draw more voltage it will balance it out?
Setup:
97 Supra White
Soon To Come:
12-06-2003, 11:54 AM
0reZepyT
but if he uses rechargeables, it's 5 x 1.2 = 6.0 volts and 6 x 1.2 = 7.2 volts, so it's not too far off. from my experience, high quality led's can handle higher voltage than their rated max voltage.
12-06-2003, 01:19 PM
Hello, I’m new to this board but will tell you this. I have a RSX with a 6 cell (Double AAA holder) that runs assume. Running a SpinBrush motor with the 11-tooth pinion mated with the blue gear. Car is rewired with 22 ga. wire throughout the entire system. With all these upgrades I still run the lights with no problems. You will not be able to mount the light board on roof of the car for the battery holder takes up this room. I ended up taping the light board on the front windshield (under body of course).
As for running a 5 or 6 cell I would run the 5 cells. Another guy at work did the 5 cells that are just about as fast. So, I just cut down a double holder with makes more room under the body. I installed quick connectors on both battery holders so it can be switch if needed.
12-07-2003, 12:56 AM
SI4562DY MOSFET chip or the IRF7389 which is the older style for what I was told. Can anyone tell me any other information about the two. I have four of the SI4562DY style on order. Does anyone know if they are stacking these like the old ones?
12-09-2003, 06:58 PM
R34 Skyline is God
The wings on that site are amazing!!! Do they need to be trimmed to fit XMODs?
My Bit: Phast motor  (Orange)
Soon to come:  (Undecided) Custom Rims
