11-23-2003, 03:38 PM
Fred Obando Rox My Sox
interchangeable bodies
can i RSU myself other bodies and put them on my Civic?
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
Yellow Front, Blue Rear Springs,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
11-23-2003, 08:13 PM
nope
the skyline won't fit on the rsx chassis. i tried it tonight @ work.
The Formula One World Championship=the best drama/reality show, ever.
11-23-2003, 08:14 PM
Re: nope
but did u try to move the back of the carwhere the 3 holes are to see if it fit then?
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
11-23-2003, 08:41 PM
Acura RSX
I think that it would work if you replace the tab in the front of the chassis and then set the chassis at its farthest setting.
11-24-2003, 12:39 AM
nope
front wheels wont turn. the wheel base seems to be shorter on the rsx chassis. the front tyres are stuck in the wheel wells.
11-24-2003, 04:45 AM
the "too many tires" guy
I noticed multiple holes in the bottom of the rear chassis. This must be for rear stretching of the chassis to fit the longer bodies. I also noticed form pics that some cars have longer and different height front lips, you know the one that slides into the front of the body.
So maybe you need the proper front lip as well as the rear chassis holes to make it fit right. Or the rear part of the car could be different for some of the cars too. A good way to find out would be to measure the driveshaft length of the car. Shorter chassis would need a shorter driveshaft to ensure proper fit of the awd kit.
Maybe a chart of this would lead to knwoing what can fit. I'm going to try to remeber to take my car to work this week and take a micrometer to the axle to get an exact measurement of it with all gears removed.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
11-26-2003, 03:47 AM
whoo hoo
i got the skyline junker body to fit my rsx chassis. pretty simple really. details in the mod forum.
