Old 11-22-2003, 02:05 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Need help mounting my eclipse!
I bought the 1/25 Fast and the Furious AMT Eclipse model kit. I haven't started building yet because I don't have any paint, but already I've run across problems:
the wheelbase is just a little bit larger than the longest wheelbase setting, and I don't know what to do. any help?
P.S. I also bought a revell camaro with the same problem.
Old 11-22-2003, 02:35 PM
cyrc's Avatar
cyrc cyrc is offline
i love lab rATS ther rad.
probably because these are 1/28 not 1/24 and also it looks too wide
death is the number one killer in america ...dont become a statistic.
Old 11-22-2003, 02:39 PM
viperkilla's Avatar
Acura RSX
Well you are probably going to shorten the body to make it fit.
Old 11-22-2003, 02:54 PM
ZipRC's Avatar
Modder-Eater
Red face
Alright, well, the body isn't too wide, the way it is there now is without anything holding it up, no tabs or velcro or anything, just resting.
Also, I was hoping you wouldn't say that I would have to trim it , I don't wanna slice the body and then epoxy it back up.
Old 11-22-2003, 03:29 PM
NiXaD's Avatar
NiXaD NiXaD is offline
Send a message via AIM to NiXaD
Looks like you can slice the front bumper off sand it a bit n throw it bak on.... I really don't see how else you could fix tat, sry for ur problem, it will probley turn out good tho.
Old 11-22-2003, 03:33 PM
viperkilla's Avatar
Acura RSX
Well its either shortening the body or finding some way to extend the chassis.
Hairball Hairball is offline
Cheese Ninja
Send a message via AIM to Hairball
You might be able to grind down the insides of the fenders where it's too close to the wheels and then add a bit to the other side.... Maybe.
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
Old 11-22-2003, 03:43 PM
ZipRC's Avatar
Modder-Eater
i could always make it have huge a$$ wheelwells like the first gen of some other car. i think the epoch spec1's had the biggies.
edit: i have all the supplies to make resin molds from back when i wanted to mold zipzap bodies. you think I could cut down the body and use resin to smooth it out?
Old 11-22-2003, 03:49 PM
Cheese Ninja
I think that if you cut it and just slather it with epoxy or whatever you wanna use, then smooth it down with a dremel, or go old-school with sandpaper.
Old 11-23-2003, 03:43 AM
security civic security civic is offline
sleeper mall civic
Send a message via AIM to security civic
(looks at avatar) oh yeah anyways ur probably gona have to do some cutting and i was gona do the eclipse body also, good luck let no how it turns out (keeps looking)
carbonfiber black civic, body kit with mixed wild and mild,white supra rims cf hood, lights 1' antena evo front bumper for racing and some shows stage 2 motors,hard treads in back with hard springs and soft slicks and soft springs up front ,running drift for now and 3rd chasie
douglascounty!!!
Old 11-23-2003, 08:47 AM
aero528's Avatar
aero528 aero528 is offline
like my dog??
Send a message via AIM to aero528
how do you set the chassie to its "longest setting"?? does it just come that way??
--Chris
Aka...aero528
Old 11-23-2003, 12:30 PM
ZipRC's Avatar
Modder-Eater
to get it to it's longest setting, on the bottom are two screws, they're near the back of the car. unscrew those, and you can slide the car shorter or longer. for the longer, you will need the long driveshaft, whichcomes in all the cars but the rsx i think.
ok, i decided to chop it up, and work from there and see what happens. there's approx. a half inch wheelbase difference between the car and the body. i was thinking of taking a strip of masking tape 1/2in. thick, and running it across the doors/roof of the car. this'll serve as a guide as to what part i'll chop out. any ideas as to what to use for cutting? im hesitant to use the dremel.
Old 11-23-2003, 01:06 PM
ZipRC's Avatar
Modder-Eater
Here's an image (sorry i forgot to resize) of what i plan to chop out. the blue strip is tape, and everything under it is going. i figured that's the easiest part to chop out and repair, because there's no glass windowing on the sides, so i wouldn't have to worry about that, and it's not crossing through too many things. but if you see a better spot to cut away, please tell me.
Old 11-23-2003, 01:18 PM
rallger's Avatar
rallger rallger is offline
switcher
Send a message via AIM to rallger
that looks like a good place but hows the scoop gonna look after you do that?
what if the hokey pokey really is what its all about?
Old 11-23-2003, 02:31 PM
ZipRC's Avatar
Modder-Eater
im not sure...i think i'll just pray and hope i have good sanding skills.
Mounting Mini-Z bodies on Xmods neurokinetik XMODS Mods and Projects 18 12-28-2005 05:13 PM
How are you mounting your aftermarket bodies? sporttracguy XMODS 0 10-16-2004 12:08 AM
question about a mitsu eclipse security civic XMODS 16 12-20-2003 02:53 PM
X_MODS 99 eclipse GST skyline-99 XMODS 19 12-20-2003 02:47 AM
Has anyone lowered the eclipse or added LEDs? zacdaddy ZipZaps 3 10-09-2002 05:33 PM
