Old 11-19-2003, 12:38 PM
Feenix Feenix is offline
Is everyone's Xmod driving straight?
My skyline likes to veer. I use the adjuster on the controller, and it temporarily fixes.
I used the instructions on this site, for adjusting the servo horn. But it still likes to veer.
Any more options? I think I am beyond the point of returning it with the stuff I've done and the wear and tear etc.
Old 11-19-2003, 12:55 PM
Se7en Se7en is offline
which tie rod are you using? might have better luck with one of the red ones in the suspension and steering upgrade.
Old 11-19-2003, 12:56 PM
stock.
thanks. I'll look into that! :d
Old 11-19-2003, 02:18 PM
SE2002 SE2002 is offline
If your car is not driving straight after adjusting the servo check to two things listed below:
1. Take the front wheels off and look for hair or fuzz around each axel. This has happede to me before.
2. Make sure each wheel spins freely after tightening down the lug nut. If one of the wheels is tighter than the other, it will veer to the side, which ever is tighter. I spin each wheel with my finger to see if both wheels spin for approimently the same time. My front and rear wheels are pretty wobly but my car still drives straight.
Also, check the rear wheel for fuzz and over thightened lugs.
Old 11-19-2003, 09:03 PM
weba2nkill3r weba2nkill3r is offline
teenage r/c maniac
Send a message via AIM to weba2nkill3r
check your diff. and unscrew your servo piece n turn on everything adjust it n screw it back on ..it happen to me b4
Biggest Fastest REDLINE "BIG BLOCK V-12" ProPulsion Dragster XMOD MOTOR Ever! MicroRCracer XMODS Mods and Projects 25 01-26-2004 03:42 PM
How to make my XMOD go straight viperkilla XMODS 5 10-24-2003 08:33 PM
Perfectly Straight Driving? ZipRC ZipZaps 1 06-21-2003 06:11 PM
