Old 11-17-2003, 09:20 PM
JesterDotcom JesterDotcom is offline
3D Racer
ESN(Electrically Simulated Nos)Help Needed
so me and a few friends came up with this idea that in stead of just hooking up more batteries we would try and simulate a controlled NOS. Any ways we thought we could make a seperate radio controlled device that when the button on its controller was pressed send 3.6 or so volts(we were thinking of using those little mini rc batteries)directly to the motor thus giving the effect of NOS. But, unfortunatley i am unable to find a very simple one channel radio controlled devices diagram thus I need everyones help at TINY RC to help complete this project.
Old 11-17-2003, 09:42 PM
SkylineEvo's Avatar
SkylineEvo SkylineEvo is offline
Skyline Tuner
Send a message via AIM to SkylineEvo
that sounds like a good idea. like u would have a nos button and when u press it, it would send more power to your engine. hmm... that's something we should all try to help with.
Skyline for life.
Old 11-17-2003, 10:12 PM
neurokinetik's Avatar
Mad Scientist
I prefer the "larger displacement" upgrade. More power all the time...
Old 11-17-2003, 11:56 PM
Stormvet's Avatar
Stormvet Stormvet is offline
Paint X-fer?? UP YOURS!
"Godsmistake" had integrated a tact switch into his remote and tied it to the Hi-Lo switch so that when he pushes it with his thumb it sends the remote into "High" trim mode. ** See his "NOS BUTTON" post in this forum **
You could use this same principal but have the additional boost come from another cell. Not sure of the wiring diagram but I will work on it and see what I can come up with.
Good Luck
StormVet
Freedom will be defended!
2003 RSX - Silver
Stage 2 (Blue)
Bearing upgrade
Suspension Upgrade (Hard rear - Soft Front)
Tire Upgrade (soft treaded)
AWD
Modded with alt-flashing red & blue LED's (Police lights in grill)
Old 11-18-2003, 03:24 PM
rsxmods rsxmods is offline
sounds awesome but i think you would would need it to be perfect to work and like in real cars it would possibly fry the engine depending on how it works
e mail me with some good help on how to upgrade a rsx if ya got any
__________________________
Old 11-19-2003, 11:24 AM
sokalxballa's Avatar
sokalxballa sokalxballa is offline
Xmod Modifier
Send a message via AIM to sokalxballa Send a message via Yahoo to sokalxballa
Idea
Here's an idea that might work. I use to pull radio chips out of the really cheap $5 r/c cars you find at like walmart. and put them it boats to fire rockets. The chip set are small enuff to fit in the car. Just mod the controler and tkat the chip out the old controller and put it in the Xmods one an give it a monmentary push switch. Wire the chip set in the xmod to give it more power when needed You could give it what ever voltage you want. I'm going to use a 12 volt N battery. Just IM And I'll explain it further if you can picture what I sayin
XMOD 1997 Red Toyota Supra //LED kit//Skyline Rims//
Blown White Stock Stage 1 motor (RIP)
Modified SBP High Torque Drift Motor
8 tooth pinion (lightened)
Nasty sleeper paint job
5th cell N-cell (rare) mod!!!
Pioneer in SBP 5th n-cell Technology.
4 IC3's 800mah Batteries & 1 n-cell (RS)
Silver RSX (Scraped Skyline and RSX)
Made from returned broken cars.
RSX and Supra Rims
All stock skyline chasis shortened to fit RSX.
Uses an RSX shaft and Broken limited slip gear.
White 6 cell Supra SBP II Hybred With unknown magnets... Bearings and oil cooled. Too fast! Eats tires
Old 11-19-2003, 04:30 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
I like the "Turbo" upgrade. Wisssss... Puff! Wisssss... Puff! .
I would rig some kind of FET cicut that dumbs extra voltage when it senses full throttle to the car, but that would be hard.
Old 11-19-2003, 05:10 PM
3D Racer
good idea sokalxballa i think i'll try that
Old 11-19-2003, 08:17 PM
Hairball Hairball is offline
Cheese Ninja
Send a message via AIM to Hairball
I have a crappy mini car I just yanked the chip out of, I'm working on getting it rigged to a battery to zap me... then I can work on getting it into a car.
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
Old 11-20-2003, 02:22 PM
sunfirerep601
Hey guys i'm currently working on something for this and for a under-car kit of neons i'll try to do them soon.
Old 11-20-2003, 05:16 PM
Silent_NightR34's Avatar
Got Mini-z?
well you can get a 2 speed bit and put the contoller chip into the xmod controller and put the pcb in the car...then take the pcb hook that up to batteries and the motor wires get hooked up to the battery holders or the pcb itself...confusing right?
Old 11-20-2003, 07:34 PM
yea a little but it sounds like it would work if i knew wat a pcb was srry cud u explain
Old 11-20-2003, 07:40 PM
aggroskater03's Avatar
aggroskater03 aggroskater03 is offline
just like on the old microsizers \
Old 11-20-2003, 08:37 PM
weba2nkill3r weba2nkill3r is offline
teenage r/c maniac
Send a message via AIM to weba2nkill3r
u can try to find out where the hi-lo thing is wired to
