Old 11-16-2003, 02:22 PM
sherifx sherifx is offline
Anybody use AWD rear LSD on their RWD car?
I know decoy over on Micro RC Center suggested that the LSD on the AWD kit is a hinderance, so I wondered if anybody just tried it on their RWD setup? I'm curious b/c I'm building a drift machine & I'm wondering if it will help any?
thanks
sherif
Old 11-16-2003, 07:05 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
if you mean the ball differential it acts like a clutch if youre using it in a RWD setup dunno bout drifting
NEVER UNDERESTIMATE THE POWER
Old 11-17-2003, 12:18 AM
martin3103's Avatar
martin3103 martin3103 is offline
Send a message via Yahoo to martin3103
Thumbs up Original diff
If you use the original differential in the rear it will give you full power to all tires. If you use the one that comes with the kit it will slip so that most of the power goes to the front. The front differential is the same as the original rear one.
Martin
Old 11-17-2003, 06:21 AM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
it doesnt' slip that much but then again, it's not gonna let you spin your tires either. great for carpet when one wheel breaks loose and you're stuck since it resists the two wheels slipping from each other
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-17-2003, 07:51 AM
neurokinetik's Avatar
Mad Scientist
I actually set mine up with the ball diff up front and the standard gear diff in the rear. That gives me AWD, but with the bias set more to the rear, which is how I like it.
BTW, I figured out a way to make the gear diffs a true limited slip. I'll post that in its own thread so it doesn't get missed...
Old 11-17-2003, 09:27 AM
platinum_player's Avatar
platinum_player platinum_player is offline
..::X-Mod Drift Team::..
you guys want a real diff, glue the differential in the stock back and it will be a posi
Skyline Chassis (lightened)
-Nuke 130SM (11t)
-Dual Li-Ions
-CF driveshaft (hollow)
-AWD (locked Differentials)
-Custom suspension
-3.0 tie rod
-Wide track bearings
-tight-turnz
-v2 board
-Soft Slicks (optional Drift kit)
Old 11-17-2003, 10:05 AM
Mad Scientist
That's not a "real diff". That's called a welded diff or a spool. Gluing the diff is both unnecessary and permanent. Using the grease method that I describe here:
http://www.tinyrc.com/forums/showthr...threadid=15211
...allows you to have a true limited slip differential. You don't want a completely locked diff unless you are drag racing exclusively.
Old 11-17-2003, 11:02 AM
badsupra1239 badsupra1239 is offline
When i drift i use the Awd and slicks red motor and red in front yellow in the back it works for me!
Old 11-18-2003, 12:32 AM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
what does dat ^ have to do wid da thread?
nice skyline though
Xmod Parts Help
Old 11-18-2003, 02:55 AM
merc merc is offline
Thats the same set up I've been useing. I've tried just about every combo and that one is the best for me.
In Car Crip Cap Questions poopeebum Bit Char-G / MicroSizers 0 11-18-2002 11:21 PM
Another Race car added to LP Racing latency ZipZaps 3 10-21-2002 09:03 PM
HELP! Car Stutters, etc. DrakZ1 Bit Char-G / MicroSizers 4 09-13-2002 05:25 PM
The M-Chassis PorscheGuy964 Tamiya M-Chassis 9 06-25-2002 12:57 PM
