Old 11-15-2003, 06:45 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
the sparco steering wheel
how do i secure it to the controller? i took otu the old one and attached the new shaft to the new wheel. i just dunno how to secure the new wheel with shaft and the locking plate on to the controller. i mean, i put a screw in at the end of the shaft like the diagram shows but it doesnt do anything, i can pull the wheel out easily and the locking plate just comes off since it isnt secured on to the controller. anyone knwo what i'm doing wrong?
Old 11-15-2003, 07:03 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
sounds like you stipped it... i would put super blue in the hole on the steering wheel then put the screw back in it, if that doesn't work try using a bigger screw.
but first make sure you have the right screw
Old 11-15-2003, 07:04 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
same happend to me and my other friends must be a defect or a miss constructed thing. I personally left it off it was so annoying cuz it always comes of when i play with it, so I really can't help you. But if somebody out there can help you, it can help me and alot of my friends
Xmod Parts Help
Old 11-15-2003, 07:05 PM
kingcobra kingcobra is offline
um....
did you read the instructions? anyways the screw goes through the back of the controller into the steering shaft...
Old 11-15-2003, 07:09 PM
Heat's Avatar
Re: um....
yes i know, i put the wheel with shaft in, then i put the plate in the back then i put the screw in thru the hole in the plate. but that screw only screws into the shaft and doesnt even touch the plate...so it really doesnt secure it. i could take a picture of it but this is what's happened so far. i assembled the wheel along with shaft. i put the whole thing through the hole in the controller. i then put the locking plate on the other side of the controller. i put screw in the hole in locking plate, i secure the screw. nothing happens, the screw is just in the shaft it doesnt keep the shaft or wheel secured to the locking plate, therefore the locking plate and the wheel with the attached shaft is loose and useless. i dunno what's wrong with it. i stripped the first screw but that doesnt matter since i found another screw that fits the shaft's hole.
Old 11-15-2003, 07:27 PM
ViperKid's Avatar
Redneck Drifter
that must be a defect....i'm glad you fixed it
Old 11-15-2003, 07:37 PM
hey...
your using the wrong screw!
Old 11-15-2003, 07:57 PM
Heat's Avatar
well the original one got stripped by my dad. the thing is more like a circle now than a cross...how big should the head be anyways cuz the hole on the locking plate is pretty wide and i dunno how to secure it.
Old 11-15-2003, 08:00 PM
Heat's Avatar
problem solved, i just put a washer in the locking plate and it's all good. so kasper u might wanna try that.
alternate four wheel steering concept frizzen ZipZaps Monster Truck 0 03-31-2005 10:02 PM
Anyone get the steering wheel "looser"? Whatup1049 ZipZaps SE 0 12-30-2003 08:42 AM
Parts for arcade type steering wheel boxes CraigG Tracks 0 05-11-2003 12:52 PM
buying steering clip and white wheel knuckles striderpunk Bit Char-G / MicroSizers 1 09-14-2002 10:51 AM
