Old 11-12-2003, 11:16 PM
kasper01001's Avatar
kasper01001 kasper01001 is offline
("\(0.o)/") Rawr!
Send a message via AIM to kasper01001
so many questions
1: I have the XMODS rechargeable bats everytime its finish recharging, I wait like 3 hr, then plug it back it, by the looks of it does not look fully charged, does it lose power over time?, I tried usein it on my XMODS, works fine but how would I know it has all the power?
2:I've been hearing that metal bearings is a good upgrade from some people, with the other people i've been hearing that they sux, so lay it down for me people is this upgrade really worth it?
3:nimh cells what are they?
4: AWD, I know it destributes the energy to both front and rear, but how can I modify it, that it would have more power and torque?
5:whats da best way to mask your car? also whats a good quality spray paint that I can buy to paint it with? also whats a good primar?
6: thats about it I couldn't think of anymore.......i'm gettin sleepy well thanks I appreciate your help
Xmod Parts Help
Old 11-12-2003, 11:42 PM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
1. Get a volt meter and test the batteries after they are charge to see if they are fuul.
2. If you have 20 bucks to blow they are great. If you do not have the extra cash wait for Tiny's bearings.
3. Nickle Metal Hydide. They are batteries that have less voltage than alkaline but deliver a steadier stream of power.
4. I do not understand the question. AWD increases handling at a loss of speed. Leave the white rear Differential in and you will loose less speed.
5. No clue, I can not paint worth a darn.
6. Your Welcome
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-14-2003, 12:36 AM
("\(0.o)/") Rawr!
Ooo the AWD thing? well I heard that AWD will slow your car because it evenly destributes the energy to the front and rear, I heard there was a solution for it, also I heard the turning radius is bad too....
also u said "lose less power" do u mean i'll go faster??
Xmod Parts Help
Old 11-14-2003, 12:55 AM
Revlis Revlis is offline
The all wheel drive is slower because instead of all the power going to only two wheels its sent through a driveshaft, more gears, and then put into four wheels.
However if you have a high power engine that spins the 2WD system when you launch you should get better launches with the AWD.
You should be able to decrease the AWD losses some if you got a lightweight driveshaft and made sure all the gears were well lubricated.
Old 11-14-2003, 08:33 AM
rob2fastx rob2fastx is offline
for the awd thing I heard putting the stock differential in back helps alot try it out and see
SE Steering Questions Azimov ZipZaps SE 49 02-03-2004 11:11 PM
questions questions questions kasper01001 XMODS 12 01-02-2004 04:38 PM
Bit-Dub Conversion questions mcojoc Bit Char-G / MicroSizers 0 09-25-2003 11:49 AM
Questions for Ahh5hit 55_BrOoKs_55 ZipZaps 8 08-25-2003 07:27 PM
Mini-x tech questions Bravin Neff Mini-X 27 12-28-2002 03:25 PM
