Old 11-12-2003, 06:22 PM
EMX's Avatar
EMX EMX is offline
I R r33t Hick
Send a message via AIM to EMX
Sanding Question
I've decided to re-paint my xmod since i ****ed it up, what grit sand paper should i use to sand off the paint i painted with?
thanks
Ian.
Old 11-14-2003, 02:49 AM
martin3103's Avatar
martin3103 martin3103 is offline
Send a message via Yahoo to martin3103
Thumbs up
I would use the highest grit I could find. 1000 +
Martin
Old 11-14-2003, 05:27 PM
dragon4450's Avatar
dragon4450 dragon4450 is offline
customanix
Send a message via AIM to dragon4450
to sand off the old paint i would use something like 100 ir 150. the to clean up the plastic i would use 400. also use 400 on the primer coats. then use 800 on the paint coats and 1500 on the clear.
and then we added the giggle gas.
Old 11-14-2003, 06:02 PM
rct_19903 rct_19903 is offline
are you sanding of the stock paint? if so you may need something more like a belt sander . they arent painted stock. they are colored plastic. so you will have to reduce your car to a pile off shavings before you get through the paint. just wipe it with a little laquar(sp) thinner and then prime and paint.
Old 11-15-2003, 02:23 AM
dragon4450's Avatar
customanix
they arnt painted stock? then i wonder why my yellow skyline is white on the inside......... did they paint the inside white then?
Is this normal? (newbie question) WSPFreak ZipZaps SE 12 12-29-2004 01:38 AM
Nero, question about Gold.... codedat XMODS Parts and Hop-Ups 0 04-30-2004 04:55 PM
Tab lowering enfini + question at the end tobenjunk ZipZaps SE 7 04-06-2004 09:42 AM
Wheel axle question! MythosGR Bit Char-G / MicroSizers 1 01-26-2003 09:31 PM
Question, please awnser quickly. Supra-00 Bit Char-G / MicroSizers 17 10-26-2002 12:32 AM
