11-11-2003, 08:51 PM
like my dog??
my flaming skiline
it is a work in progress but i will have time on thursday probley to start the painting. it is going to be my first airbrushed car(accually my first XMOD paint). i have painted some zips before but this a much more danting project. the flames will be a fade from red to the orangal yellow, and the body will be a fade from silver in the front to a silver blue in the back. i just have to get the paint!
--Chris
Aka...aero528
11-11-2003, 08:54 PM
like my dog??
--Chris
Aka...aero528
11-11-2003, 08:55 PM
Acura RSX
Whoa. That looks sweet.
11-11-2003, 08:57 PM
like my dog??
3 hope you guys like it.
--Chris
Aka...aero528
11-11-2003, 09:00 PM
What type of masking tape are you using? I would make sure it is pushed down in that door crack really good.
11-11-2003, 09:03 PM
like my dog??
thanks i will do that!!  i am using 3m masking tape. i was going to use painters tape but was too lazy. i can still do that if would work better. what do you think?? this is just to let you guys see what it will look like. i have to make the fade under the flames first.
--Chris
Aka...aero528
11-11-2003, 09:20 PM
got boost?
whoa!
own decals........very nice
cant wait to see it
when i get my xmod i think i am going to do my own decals too
keep up the good work
All Wheel Drive=Fun!!!
11-11-2003, 09:22 PM
like my dog??
thanks i just hope this comes out nice or i will be very mad
--Chris
Aka...aero528
11-11-2003, 11:38 PM
your going to get paint seepage through that masking tape... u need to be using the blue stuff... otherwise it will leak in around the edges....
also only use one large peice of tape for each part u mask
again get the blue stuff
if u overlap it gets harder to get a even line....
11-12-2003, 05:16 AM
I agree, I have experienced paint seepage thru the 3M tape before, not only around the edges, but throughout the whole area. A lot of people have had good results with the blue painter's tape, I personally use Tamiya masking tape.
11-12-2003, 08:15 AM
Garage Rocker
I've been using the 3M stuff for years. I have no problem with seepage, as long as I rub it down really good, and remember I'm sticking it to glossy paper to print my graphic, peeling it off that, and sticking it to glass to cut it, then peeling it off that, and resticking to the car. Even after all that I rarely get seepage. Just gotta rub it down really good with the back of my finger nail. Also, you should lay a couple light mister coats, before you lay heavier coats. That helps seal the edge of the tape. You don't want tape that sticks too good, because it might pull paint off with it.
But, despite my endorsement, regular paper masking tape of any brand or type is less that ideal for these cars, because it's too thick, and will leave the edges raised up. I lightly sand to help level it. Also because it doen't stretch very well, and has a tendency to wrinkle on contours. I use multiple pieces to avoid the wrinkling.
Ideally you want some masking film from your LHS, or towerhobbies.com. It is a very thin and flexible plastic, making it easier to work with, and giving you nicer crisp clean edges.
11-12-2003, 02:56 PM
you are not your xmods
gunan look great! but make sure the masking on the black part of the wing is all the way on the black part ... unless u want it like that. and also you should try to cut that excess away from the headlights. like i said lookin good .... and get that paint soon im itchin to see it
I like the way you drive. Hittin walls and bouncin on the sides. Cuz the glare off my rims hit ur eyes
11-12-2003, 03:09 PM
like my dog??
thanks again!! i am going to my lhs to get the paint (testers boltted enaml) so i will get the film if they have it too. i have painted modles with this tape and it seeps throught the edge a little, but i dont want to take a chance on this. if i can not find the film then i will use the blue painters tape. what is the exact name of the film or will they know what i am talkiing about?? as for around the headlights, i am taping under the lights (on the front bumper) and the back of the light(on the body). i hope i can get the fade right, i have tried it before with spary paint and it worked pretty well, so we will see. when i take the tape off will it take some of the paint around it off if i am not careful?? i have just paint things with about 2 coats before, so i dont know about more.(i am going to paint this one right with lots of coats)
--Chris
Aka...aero528
11-12-2003, 07:04 PM
Garage Rocker
I know Pactra makes masking film in sheets, and thin pinstripes. Your LHS should carry Pactra, if not, they should at least know what your talking about.
11-12-2003, 08:09 PM
like my dog??
ok ill ask them tomarro. iwill post pics tomarro if i get some of the paint on. i still am wodering if i should prime it?? i think i will just to be careful.
--Chris
Aka...aero528
