Old 11-11-2003, 04:47 PM
xmodskylineman xmodskylineman is offline
what is best for removing old paint
i would like to know what is best for removing paint if you messed up or somthing
Old 11-11-2003, 06:15 PM
SR20DETT SR20DETT is offline
^^^^Depends on how you want to fix your mess up. If your going to repaint the whole car, you can use a mild paint thinner but be extremely careful as thinner can melt plastic but this only works well if the paint is not dry. Or if you want to try and fix the problem you could try and spot paint in the bad section. Either way you will need Scotch Brite and possably a really fine grain sand paper say 1200 or so. It is essentially the same way a body shop would fix a paint mess up but with a whole lot more care and delacasy. Good Luck, PEACE
If your going to grab the shark by the tail, you'd better have a plan for dealing with the teeth.
Old 11-17-2003, 02:38 PM
cmuench cmuench is offline
Supra king
Send a message via AIM to cmuench
Paint remover
I bought this stuff at Johnnys Toys that will take the paint right off and not harm the plastic one bit. it was 7.99 but I can not remember the name of it. I used it on my supra and the skyline I am repairing for my friend. I will get the bottle tonight and get the name
**1997 Supra Xmod**
-Stage 10 Motor w/11 tooth
-AWD
-Wild body w/ Custom paint
-6 AAA battery mod (7.2v)
-Double head/tail light mod (Not used with 6 cell)
-Hard suspension w/ 4.5 toe-in
-upgraded wheels with hard tires
-Metal bearings upgrade
Old 11-17-2003, 02:39 PM
viperkilla's Avatar
Acura RSX
I'd have to say GOO-GONE. I love this stuff!!! This takes off paint like magic. Its good for touching up or taking off a whole coat of paint. I highly recommend you use this.
Old 11-17-2003, 10:40 PM
LittleBlueRocke LittleBlueRocke is offline
Dr. Pepper Warlord
You can use brake fluid to strip paint off really quickly.It is mainly used to strip down lexan bodies in a short period of time,but I doubt it would harm the plastic of these bodies.
Original 27 MHz Blue Skyline MicroSizer RIP
New MicroSizers Pro
Old 11-18-2003, 04:24 AM
Cian's Avatar
Cian Cian is offline
Got Cheese?
I have heard that Brake fliud will turn clear Styrene milky (headlights etc..)
Anyone else noticed this?
Lisa: And vice versa...
Old 11-18-2003, 05:03 AM
Bad Company's Avatar
I would remove the lenses anyways. I'm gonna try this with one of my bodies I want to re-paint. How long would you leave it in the brake fluid?
Old 11-18-2003, 05:10 AM
Cian's Avatar
Got Cheese?
15 mins tops, any more and the plastic starts to soften too much. As you said, stripping down is essential, remove all metal screws as well as anything else that may be damaged... brake fliud is not a kind substance... ;D
Old 11-18-2003, 06:54 AM
Supra king
Use scalecoat II. stuff is the best. will not damage the plastic one bit, even if you leave it in for a day.
**1997 Supra Xmod**
-AWD
Old 11-18-2003, 04:24 PM
Biohazard87 Biohazard87 is offline
Send a message via AIM to Biohazard87
i used this stuff called opps and it didn't hurt my body at all
Old 11-18-2003, 06:54 PM
aggroskater03's Avatar
aggroskater03 aggroskater03 is offline
SANDPAPER
JUST SAND DOWN ANY ROUGH SPOTS AND PAINT EIGHT OVER IT
Old 11-18-2003, 08:36 PM
viperkilla's Avatar
Acura RSX
I've tried nail polish remover. This stuff works great but it can take off the factory coat of paint though. So be careful!
Old 11-18-2003, 09:09 PM
Rotary Freak's Avatar
Rotary Freak Rotary Freak is offline
Send a message via AIM to Rotary Freak
I used to give my Bit bodies a paint thinner bath, just drop em in a jar of it, swirl, leave it in for a while, then take it out later on and remove the stuff with something like an old toothbrush. Worked like a charm...too bad I sucked at painting.
I wish my Land Rover was a rotary
Paint in a Can! ~S20o0~ XMODS Parts and Hop-Ups 10 01-31-2005 02:03 PM
What do i need to paint my Xmod ron6 XMODS 11 10-27-2003 10:39 PM
How to Paint Lexan Bodys headhunter555 ZipZaps 14 02-26-2003 04:35 PM
Paint Jobs For Sale/trade! Superimport2nr For Sale/Trade 12 01-25-2003 09:31 PM
