Old 11-10-2003, 09:54 PM
GhettoFiedRacin's Avatar
GhettoFiedRacin GhettoFiedRacin is offline
you are not your xmods
Send a message via AIM to GhettoFiedRacin
Unhappy (sometimes)sticky steering
Dont get me wrong Im in love with my new civic. Its just that the steering sticks in the left direction sometimes... most frequently when in reverse and spinning around. What could be causing this and is there a fix? Any help is apprecfiated and thank you in advace.
I like the way you drive. Hittin walls and bouncin on the sides. Cuz the glare off my rims hit ur eyes
Old 11-10-2003, 11:07 PM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
Have you tried to take the front end apart and see if the servo sticks when the front end is off? If it does it could be a bad servo. If it does not than try cleaning every part of the steering set up, tie bar, ball joints, etc.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-11-2003, 02:40 PM
its done this out of the box .... and my chassis and body is a little bashed up .... do yall think i could/should still be able to take it back?
Old 11-11-2003, 02:50 PM
viperkilla's Avatar
Acura RSX
Like I tell everyone else. There is a good chance you can return it. As long as the sratches and banged up-ed parts arent too noticeable.
Old 11-12-2003, 03:03 PM
well i fixed the probl;em .... i took the entire front end apart and noticed something loose so i just adjusted it and now my problem is fixed. THANX AGAIN
Ideas on how to increase steering power mde Bit Char-G / MicroSizers 4 05-01-2004 02:42 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 12:16 PM
Steering Help ZipRC ZipZaps SE 1 09-21-2003 09:57 AM
Steering issue cdog4w Bit Char-G / MicroSizers 21 12-30-2002 10:20 AM
