Old 11-09-2003, 04:06 PM
kevinsupra90's Avatar
kevinsupra90 kevinsupra90 is offline
Brownie Cheesecake
Thumbs down What is wrong with my Zip?
I just got a ZZ SE today, maybe half an hour ago, and I put it together right, but it just won't charge! I've tried maybe twenty times so far, the car on and everything, but the light just turns greenish-orange. What do you think could be wrong?
My 2 Mini-Zs are like cake, mmm...cake. My 3 Zips are like gerbils, small, quiet and cuddly.
Old 11-09-2003, 04:43 PM
ax0n
you need to turn the ZZSE's power switch to ON on the car before it will charge. The controller needs to see that it's a real ZZSE and send the channel number to the car before it will charge. it should blink for 10 seconds when you first put it on the charger, then it should start charging, I believe it's a solid red light till it's done charging.
Old 11-09-2003, 05:58 PM
viperkilla's Avatar
Acura RSX
Make sure the chassis is turned on and if the lights are plugged in (my SE doesnt charge unless the lights are plugged in, weird). Also make sure the channel is set onto channel 1 when you are going to charge. If you still have problems then just return it.
Old 11-10-2003, 10:01 AM
Canadian Bit's Avatar
Canadian Bit Canadian Bit is offline
You can't beat it.
Yep, have it on and wait for the blinking to stop for 10 secs, then try again if the light turns amber.
Old 11-10-2003, 12:36 PM
Brownie Cheesecake
Thanks, I always turn on the power, though. I haven't tried the channel 1 thing yet, but I will.
Old 11-12-2003, 07:06 PM
Brownie Cheesecake
GOODY!
I actually took it back on Tuesday, and got a brand new, shiny RX-7 Enfini. It works awesome, though I do remember a thread about the turning. It is snappy to the right and loose to the left.
Zip Zap SE FAQ Bad Company Tips, Mods and Reviews 4 11-16-2006 08:21 AM
Panther Chariot Zip clone Azimov ZipZaps 12 08-24-2004 09:16 PM
What wrong with my Zip Zap? ssghchd ZipZaps 0 12-30-2002 10:17 PM
my modded zip vs. all my other cars natedogg4674 ZipZaps 0 11-04-2002 05:32 PM
swapped pcb into my zip natedogg4674 Bit Char-G / MicroSizers 4 10-16-2002 01:53 PM
