Old 11-06-2003, 11:58 PM
martin3103's Avatar
martin3103 martin3103 is offline
Send a message via Yahoo to martin3103
XMODS Problems
As some of you may have guessed I have the Nissan Skyline. I have heard alot of bad things and well it is true.
The first one I had the controler wouldnt go in revers. Also there was a loose wire.
I took it back. The second one the remote would cut out on the throttle but the steering wuld still work turned out to be the throttle board in the remote was loose.
The steering was puling to the left then the right ect. Finaly I found that one of the nylon bushings was to tight on the front left tire causing the intermitent pull. And finally the rear axle froze. I took it apart and got it to work a few times. It is working now but im not sure if it is fixed.
Martin
Old 11-07-2003, 12:13 AM
martin3103's Avatar
Differential
Above you can see the motor and front+rear drive gear That drives the differental gear. Here is the differental gear in one piece. There are no springs so taking it apart is easy and safe.
Martin
Old 11-07-2003, 12:23 AM
martin3103's Avatar
Break Down Differential
Here is a picture fo what is inside of the gear. the gear is in three main parts the gear face, gear backing, and the pilot gear guide frame. Then there are 3 pilot gears and 2 drive gears that drive the axles.
Martin
Old 11-07-2003, 12:33 AM
martin3103's Avatar
Good Luck
I hope these pics and discriptions help someone. If anny one has the same problem or a posible solution leave a post. The last thing I tried was to switch the axle drive gears so far it is working. But im not sure that it is realy fixed.
Here is a picture of the problem car.
Martin
Old 11-07-2003, 11:58 AM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
if the rear axle froze try getting the AWD kit and use the gearlube on it. ir you dont want to spend the money, use WD-40. i havent tried this but i think that if you have the straw you can just spray it into the holes on each end. but not a lot. then the rotating motion should lube everything.
NEVER UNDERESTIMATE THE POWER
Old 11-08-2003, 04:40 AM
martin3103's Avatar
Actualy I have been lubing the axle and the other parts I think that there is a little wear on the shorter plastic axle on the left side.
Thanx for the advice about the awd kit i was thinking of it and if the problem persists I will turn it into a fwd until they make replacement parts you can buy (at a reasonable price).
Althow I don't have mutch hope that they will actualy sell indavidual parts it would be very nice to see. At this point it seems that they don't plan to even come out with new body styles. That would be nice to if they sold just the body so you could change the car tops. Thanx again and good luck.
Martin
Old 11-09-2003, 03:17 AM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
It is hard to tell from your pictures but the gears look a little dirty. If they are try cleaning them with a tooth brush and a little rubbing alcohol. Then relube them.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-09-2003, 05:38 PM
kevinsupra90's Avatar
kevinsupra90 kevinsupra90 is offline
Brownie Cheesecake
The AWD kit supposedly kills handling...
My 2 Mini-Zs are like cake, mmm...cake. My 3 Zips are like gerbils, small, quiet and cuddly.
Old 11-09-2003, 08:16 PM
I have a beach ball...
This couldn't be further from the truth. It increases handling by a great margin.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-10-2003, 03:52 AM
martin3103's Avatar
Thanx
Cool guys. thanx for the info keep them coming. By the way the gears were dirty when i took the pic. I took it as soon as i got it apart. but i cleaned them after that. As for the problem it looks like the nylon bushings may be the problem.
Martin
CJ's Xmods FAQ (Updated June 27th.) cj1267 XMODS 64 05-30-2007 08:43 PM
XMods Charger and AAA NimH Batteries rfnagel ZipZaps 3 05-14-2006 12:41 AM
Mini-Z VS. XMODS jerm781 XMODS 16 10-19-2003 10:17 AM
Xmods Announcement cj1267 XMODS 2 10-16-2003 05:34 PM
