Old 11-05-2003, 04:57 PM
geofroley's Avatar
geofroley geofroley is offline
R34 Skyline is God
Send a message via AIM to geofroley
Custom rims
First off, how do I remove front rims off the knuckles and rear rims off the axles? Also, if a hole for mounting the rims is too samll or doesnt have a hole, how do I make an accurate hole?
Old 11-07-2003, 08:24 AM
Lord_HelmetR34's Avatar
Lord_HelmetR34 Lord_HelmetR34 is offline
Bit Crazy
What kind of wheels are you trying to mount on the car? As far as removing the front wheels, If you don't care what happens to the origionals, take a cutter and cut them off the pin, then pull the pin out with pliers (heating the pin helps)
For the rears, I would just cut them off. I don't recommend heat because it can damage the axle gear or warp it.
I have a tutorial on mounting modifier rims to a bit. check it out and see if it helps
If you need to enlarge the holes in the front wheels, take a thick needle or a small dowel and heat it up . The best way would be a small drill bit. Take the tires off the rims and hold them with a pair of pliers. Make sure to go slow and hold the drill straight down.
modifier wheel tutorial
Dubshop Customs
Old 11-07-2003, 04:24 PM
geofroley's Avatar
R34 Skyline is God
Thanks dude. Can you tell me what rims would be good to mount on a bit? I'm talking what brands and stuff. I got some Muscle Machines but they were too small and they were two piece.
making custom rims rydzjunior XMODS 4 10-24-2006 09:01 PM
Directions on Avatar, and Custom Title MicRoMaN TinyRC.com Shop Support 11 09-10-2006 10:24 PM
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 08:53 AM
custom wide rims broke ess supra XMODS Mods and Projects 1 07-18-2005 07:59 PM
custom rims geofroley Bit Char-G Mods and Projects 5 09-09-2003 03:59 PM
