Old 11-05-2003, 02:49 AM
ron6 ron6 is offline
BC i need help with my car
BC i need help with painting my car i have everything i need to paint my car. I have tamiya paint and primer,masking tape and an x-acto nife. I have goten most of the paint of my skyline but the paint wont come of the plastic lense peace what should i use to get it off. I would also like to know how many layers of primer i should use and how long should i leave it before i paint it and how many layers of paint should i paint itl. Sorry for asking alot but i have never painted an rc car so i whant to make sure it comes out right .
Thanks
Old 11-05-2003, 03:10 AM
I have a beach ball...
Why don't you email him? Might work a little better.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-05-2003, 05:50 AM
Bad Company's Avatar
I will go ahead and post this here, because it may be of use to others as well.
First off (even though too late in your case), I don't even bother removing the old paint. I haven't tried removing the paint from the lenses, but someone said brake fluid? Just be carefull. (I make my own clear lenses.) The first thing I do is remove the lenses by removing the glue holding them on the inside of the body with a Dremel, then just pop them out.
Next, I wash the car in dish soap and warm water, and then let it dry completely. Then apply your masking tape over the windows and cut the edges out with the X-acto knife. Also mask off anything else you don't want painted.
I usually apply enough primer to cover the entire car, and one extra coat after that, usually 2 good coats. When using Tamiya spray paints, I wait about 10 minutes between coats ( same for between the primer and color, and the color and clear coat.).
Depending on the color, I will apply anywhere from 6-8 coats of color. I spray from about 12" away with 2 steady passes per coat on all sides.
Finally I apply 2-3 coats of clear coat. Tamiya paints dry fast, so I wait about 25-30 minutes, and carefully remove the masking tape. If you wait too long, you make get cracking at the edges, but if you do it too early, it will not be a clean edge (due to the still goo like state of the paint.).
Try not to touch the paint while removing the tape. Wait at least 8 hours before handling the car.
My Car doesn't work! Eyemfaster XMODS 2 03-02-2005 10:59 PM
my drag car 4 trade zombiebaby For Sale/Trade 5 01-25-2003 02:35 PM
What gears and motor should I use to get the most power out of my car with a trailer. AudiTF Bit Char-G / MicroSizers 6 11-14-2002 05:38 PM
Cat5 vs Cat5E for car antenna material mechanist ZipZaps 6 10-13-2002 01:59 AM
