Old 11-04-2003, 05:34 PM
guce guce is offline
Send a message via AIM to guce
posy traction
i have taken the rear differential out and took it apart. i locked up the gears inside to make it a posive traction differential instead of a limited slip differential. givs it a better jump off the line and the wheels spin simontaniously. not really healthy but it is affective.
DCS Douglas County Style
Old 11-05-2003, 11:14 AM
_revhards13 _revhards13 is offline
I think thier cute!
Send a message via AIM to _revhards13
sounds liek a useful mod... do you get better drifts or powerslides?
All xmod parts for sale cheap check it out
http://tinyrc.com/forums/showthread.php?s=&threadid=15531
Old 11-05-2003, 04:37 PM
mbartell mbartell is offline
so I re-wired it
Actually the ball rear diff is more like a posi. (and a little like a slipper clutch if it's loose)
If you want to make a locker- like a solid axle, use silly putty.
Open up your gear diff.
put a small ball of silly putty on each gear
squeeze it closed, and your differential will be locked solid.
This will help more for drag and straight line. It will make the car skid around more, and I guess you could call that drifting, if you want to.
The best part is that you can take it apart and remove the silly putty, unlike glue or epoxy.
Uhh, gee thanks Radio Shack.
Famous last words:
Hold my beer and watch this
Old 11-30-2003, 11:50 AM
RSXRacer001 RSXRacer001 is offline
Put Custom User Text Here
Send a message via AIM to RSXRacer001
is the ball diff. hard to take apart? i have also known people to sick paper in it. does that work or does anyone know?
Old 12-02-2003, 10:26 AM
so I re-wired it
the ball diff is the same 3 screws as the regular diff, but I don't want to go chasing all the little peices down. Plus, you should have and extra geared diff, because that's what it comes with stock.
anything can be used to lock it. I just use silly putty because it's easy to put in and take out. Paper would also be a good solution. anything to keep the gears from moving.
You can also use thick heavy grease- that will give you a little differential action but not much.
Famous last words:
Traction Compound Respect Bit Char-G Parts and Hop-Ups 1 11-13-2003 05:49 PM
need traction? westbitchopers Bit Char-G Mods and Projects 3 08-15-2003 07:18 PM
traction!!! misterbungle Dynamite Rocket Racer Parts and Hop-Ups 3 02-19-2003 02:02 PM
