@helldriver
I made the same experience as you did. I burnt my stock motor within 5 minutes driving with the monster wheels.
I am using 6 cells and a GM SX3R esc, which has no limit with 130 and 180 motors. So I decided to use a Topcad R2 Modified motor. I use this motor in the overland as well, and i think it is one of the best 130 you can get - comparing price and value. It is fast and has a lot of torque.
Going 4 wd with a standard 130 motor means modifying the gear box and changing the motor mount - but "how to".
I had the same idea as you, using a main power shaft with a pinion and spur gear combination. My pinion gears are from the overland or hpi micro. I have them from 9T to 13T. The spur gear is from a cd-rom drive with disc changing mechanic. The diameter was perfect to fit on the drive shaft without changing/cutting the chassis.
Overall gear ratio is 12 : 1
pinion gear (motor) 9 T
spur gear (power shaft) 25 T
pinion gear (differential) 8 T
differential gear 35 T
The ratio between pinion and spur gear is 2.77 (25T / 9T), which is near to the ratio 2.67 (34T / 12.7T) calculated by "Hooters Driver" in your "get my motor burnt" thread
I did not change the pinion gear yet, because the car goes pretty good, almost to fast
@Alexman
Here are some thread's for you:
raising the chassis
http://www.tinyrc.com/forums/showthr...threadid=13599
power shaft
http://www.tinyrc.com/forums/showthr...threadid=12707
tires
http://www.tinyrc.com/forums/showthr...threadid=13880
Maybe i will make a "how to?", if there is enough interest. But i have to do more real offroad testing, to be sure that everything works well. I already changed the steering, cause i broke two sub-micro servo. Now I am using a Hitec HS85 with metall gear and a servo saver from the Hpi Micro. I hope that this combination performs better than the one shown in the pics. But something else will break - i am sure
@Cian
Thank you.
But, most (if not all) of the mods i have done, were already posted in this forum. I had some of the ideas too, but the posts of the "mini-x masters" help me a lot - especially in avoiding mistakes. So the honor is not on my side. Maybe with my next mod
diets - 6T pinion gear and hill climbing is no fear
