Old 11-03-2003, 03:18 PM
vejur79 vejur79 is offline
Ball Diff Behavior
Hi,
I put the AWD drive in my RSX with the ball diff in the rear. Just some questions.
How tight should the ball diff be? When I hold the two front wheels still and turn one of the rear wheels, should the other wheel turn in the other direction? If so, how loose should it be?
Essentially, I would like to know how the ball diff should act. I did try the gear diff in the back and the rear wheels spun in opposite directions really easily. But with the gear diff, when I turn one of the rear wheels, the other wheel doesn't move. I was wondering if some ball diff grease would help.
Thanks,
Ron.
Old 11-03-2003, 06:05 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
all right. my dad explaned this to me. the ball diff is more of a clutch than a differential. when the front wheels turn one wheel spins faster than the other and the rear diff should slip a little so one will spin faster than the other. therefore it turns like it should. if you put the gear diff in it will hurt your turning a little. (tried it out for myself and it does have a wider turning radius). don't lube the diff. a hard differential also helps lock up the front tires
NEVER UNDERESTIMATE THE POWER
Old 11-03-2003, 11:38 PM
I have a beach ball...
On the ball diff, if you turn one wheel the other will do one of two things. It will either spin in the other direction, or it will spin the same direction. If the other wheel doesn't move at all, your diff needs to be replaced.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-04-2003, 11:47 AM
aperson's Avatar
you're thinking of the gear differential. with a ball diff it acts more of a clutch like on the old RC 10s that Team Associated made. the other wheel might spin in the same direction if you hold the diff, but it shouldnt spin the opposite way. it will spin the same direction or not spin at all.
Old 11-04-2003, 04:51 PM
No, I'm thinking of the ball diff.
'65 Ford Mustang
All the RS goodies
Wanted: Front Ball Diff for mRS4 k_bojar Micro RS4 - YourMicro.com 0 04-07-2006 12:42 PM
Is the rear ball diff adjustable? eetoi XMODS Parts and Hop-Ups 14 04-04-2004 01:59 PM
Kawada ball diff. for tripmate ikinari Kawada Tripmate M-24 1 08-10-2003 10:22 PM
Mini-Z Overland Ball diff and PN S01 motor chelboed For Sale/Trade 0 07-30-2003 01:08 AM
