Old 11-03-2003, 12:31 AM
YeLLoW GT-R R34 YeLLoW GT-R R34 is offline
Send a message via AIM to YeLLoW GT-R R34
Diagram of the Rear Differental Gear
Well, I was assembling my AWD......my stupid friend took apart the rear differential gear and I dunno how everything is put.....can anyone help?
Old 11-03-2003, 01:17 AM
corysmith's Avatar
corysmith corysmith is offline
Fred Obando Rox My Sox
Send a message via AIM to corysmith
IS THIS IT?
HTTP://66.207.2.168/MY%20PICTURES/CARCR/CARCR.JPG
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
Yellow Front, Blue Rear Springs,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
Old 11-03-2003, 01:47 AM
nope dude......i meant the inside.......but thx anyway
Old 11-03-2003, 03:26 AM
Firepony's Avatar
Firepony Firepony is offline
Send a message via ICQ to Firepony
ok their are 3 parts of red plastic and 4 parts of white plastic . the 1st red part is the side with the gear teeth on it so place it teeth side down on the desk or what ever is flat. next Place one of the small white gears with the teeth up inside the red part . next you will find the middle part of red plastic its a round part with 3 triangle looking holes it in it one side is ver flat place ontop of the white gear you just put inside the 1st red part. next take the 3 small white gears and place them inside the triagle holes they can only fit 1 way. now you should only have 3 parts the 1 part you just assembled and 1 white gear and 1 red part place the white gear inside the 2nd red part kinda looks like a cap now take that and put it into 1 sold red gear and replace the 3 screws and you have your rear defrental gear
Old 11-03-2003, 03:42 AM
Firepony's Avatar
I do not write well and a picture is worth thousands of words. so here I drew you a picture.
http://www.geocities.com/fyrepony12345/
Old 11-03-2003, 06:25 AM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
lol
All Wheel Drive=Fun!!!
Old 11-03-2003, 09:58 PM
lolx...thx.........but doesn't it have those little marble ball things?
Old 11-03-2003, 10:35 PM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
That ball diff is fairly simple to reassemble.
start with the diff gear piece facing down, the 3 screw posts on it facing up.
find 1 of the small plastic washers with the D hole in the center, place 1 steel washer on this piece.The steel washer will fit only one side.
put the small plastic washer along with the steel washer into the gear side of diff, steel washer facing up.
find the center red/plastic piece and carefully lower it over the gear side of the diff.it fits tight around the 3 screw posts.
now locate the little ball bearings and carefully drop them into the 5 holes.a little bit of AWD grease on the end of a small screwdriver or hobby knife helps to pick and place these.
next locate the other small plastic D washer and steel washer and put them down on the center diff ring that has the 5 steel bearings, steel washer facing down.
lastly find the back cover (has the 3 screw holes) and place it over the assembly.it can only fit 1 way.
you have to work the shafts in a bit since the plastic washers dont line up exactly and dont forget the thin steel pin that goes into both shafts to help keep the shafts aligned in the diff.
I hope this helps.
Wheel Weights! Steve ZipZaps Monster Truck 54 05-24-2006 12:40 AM
2 speed transmission idea xxspeednplayaxx XMODS Mods and Projects 106 05-23-2005 09:59 AM
The maximum gear ratio..... charliebrown ZipZaps 9 01-13-2004 03:55 PM
Seperating gear and wheel from rear axle Minisizer Bit Char-G / MicroSizers 3 01-12-2003 03:21 PM
