Old 11-02-2003, 11:50 PM
-CRX-
Mini z motor?
alright i need to go faster ive bought everything i can buy and ive even added extra batteries and its still not fast enough, i was wondering are the mini z motors bolt in? if not is there much modification that needs to be done to fit them? i just got some more cash so does anyone recommend any specific motors? im going mostly for speed and some turning capabilities not big on drifting.
thanks guys
Old 11-03-2003, 11:29 AM
-CRX-
ANYONE?
Old 11-03-2003, 01:39 PM
-CRX-
would my lhs carry this? how much did it cost? any saudering required?
Old 11-10-2003, 03:02 AM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
CRX check this thread for info about the xspeed motor. Also any shop that carries mini z cars should carry the xspeed motor.
http://www.tinyrc.com/forums/showthr...ghlight=xspeed
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-10-2003, 03:23 AM
cdigg cdigg is offline
Send a message via AIM to cdigg
Originally posted by tkklemann
Yes, Mini-Z motors are a bolt in. I have the X-Speed motor in my XMOD is quite fast now...
you did not run across the same problems with your x-speed motor that Hudson5150 did?
Old 11-10-2003, 07:51 AM
neurokinetik's Avatar
Mad Scientist
Keep in mind that the motor running in reverse is not a major problem. The motor is still much faster than a stage 2, even though it is essentially "detuned".
Measuring Motor RPM backtrack9 XMODS Science 9 01-12-2004 05:00 PM
Motor current draw findings... neurokinetik XMODS Science 45 01-08-2004 03:42 PM
Can yo use mini z motor in a x mod census007 XMODS Mods and Projects 4 12-25-2003 08:17 PM
180 Motor upgrade sono XMODS 4 12-24-2003 03:02 PM
Strange Observation, zip zap red motor in a 1 cell bit booster, and in a tricell. Clint Bit Char-G / MicroSizers 3 03-20-2003 12:58 PM
