Go Back   TinyRC.com > Customer Support > bitchar-gmotors Customer Support
Old 10-01-2002, 06:48 PM
ICH_BIN_GUT! ICH_BIN_GUT! is offline
Send a message via AIM to ICH_BIN_GUT!
Question how can i modify the zipzap chip?
I saw that really cool modified Zip Zap/ Bit G in the mod. section of the forum. I was wondering if that is something really easy to do. Since there are only 6 wires on the bit G its not that hard rite? The boards are different in the cars but I dont know much about the ZZ ones.
Could you show me the steps or give any tips?
Old 10-01-2002, 07:41 PM
bitchar-gmotors bitchar-gmotors is offline
ICH_BIN_GUT!
I'm not the best with a soldering iron, so if I can do the swap, you will probably be able to do it too. Just open up both cars and take a good look at the locations where the wires are soldered. The wires and locations are almost identical for both cars so it shouldn't be that hard to figure out what goes where. I suggest starting by taking the bit board off completely, making sure to leave the colored wires soldered to the board, but unsolder the very fine steering wires from the board. Then unsolder the colored wires form the Zip Zap chassis and solder in the Bit Char-g wires into the Zip Zap chassis in their corresponding locations. Lastly I suggest moving the fine steering wires from the Zip Zap board, one at a time, to the Bit Char-g board. This way you won't get them mixed up. Both boards are marked with L and R for the steering wires and the other two will connect to the same spot as the red power wire. Everything worked for me the first time I did the swap, so I'm sure there are alot of guys out there who will be able to do it with no problems. If you have any questions, I'll try to help.
Kyle
Old 10-02-2002, 05:57 PM
sounds like a good mod worth doing
You should make an article bout the thing on TinyRC.com
zipzap and zipzap se? xmod456 ZipZaps 8 01-24-2005 04:11 PM
just went through my parts box....... airbob20 For Sale/Trade 10 01-25-2003 11:21 PM
Zipzap motor and PCB dtmracer ZipZaps 4 10-17-2002 05:01 PM
BItDra-G times recorded for 2.4v ZipZap QFM Racing Bit Char-G / MicroSizers 13 10-01-2002 09:15 AM
