Old 10-31-2003, 11:08 PM
Bad Company's Avatar
How to Splice LED's for the Light Kits
OK, I'm going to be using the left over tail light LED's from past projects, but it all applies the same for the head lights, so here we go...
You will need:
2 Light Kits (Or more)
Scissors (Or knife)
Electrical Tape
Do not do this with the light kits hooked up. (Duh!)
First, cut and remove the LED's from your second Light Kit. I suggest cutting them close to the board to have enough wire to rtun them wherever you plan in the car. Seperate the wires on each LED, and use the scissors to strip the ends. Be carefull to only cut away the insulation, do not cut into the wire. It helps to twist the strands in each wire together after striping them.
Old 10-31-2003, 11:10 PM
Next, seperate the wires on the light kit you will be installing. Do not seperate them all the way back to the board, this will keep them in the correct pairs (each side).
Old 10-31-2003, 11:11 PM
Next, cut the wires on the light kit you are installing in the middle and strip them just like you did before.
Old 10-31-2003, 11:14 PM
One thing to remember here...
Each pair of wires to each LED have one plain wire and one with a white stripe. You have to match all your wires up when splicing them back together. (Plain to plain, stripe to stripe.)
Now, match the seperated LED's up and twist the plain wires together for two of the LED's. Then twist the striped wires together.
Old 10-31-2003, 11:16 PM
Now take those two LED's, and twist the plain wire to the plain wire going to the board. Do the same for the striped wire.
Old 10-31-2003, 11:17 PM
Now fold your wire over on the insulated part (I usually fold it over on the wire to the board.) and wrap some electrical tape around the exposed wire. Repeat these steps for the other side, and for the headlights.
You are done.
Old 11-01-2003, 08:29 AM
Silent_NightR34's Avatar
Got Mini-z?
Great tut! i gotta get some more light kits soon...
Old 11-01-2003, 09:27 AM
viperkilla's Avatar
Acura RSX
Thanks bad company. I am definitately try this when I get 2 light kits!
Old 11-01-2003, 01:24 PM
Nii Nii is offline
So if i wanted to splice in a third or fourth set i just do the same thing but and that third or fourth set?
Old 11-01-2003, 01:25 PM
Nii Nii is offline
Nevermind, I understand now
Old 11-01-2003, 03:28 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
very nice tutorial! your quite the modder i'm a sucker for light kits and the general rule of thumb for me is, the more lights the better
Old 11-01-2003, 05:47 PM
dEmOnRaCeR's Avatar
dEmOnRaCeR dEmOnRaCeR is offline
"Its OK I had subway"
very nice but does it use the batterries faster or no difference
Old 11-01-2003, 08:26 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
a about 20 mA (typical of many led's of this size) battery life shoudln't be that affected...unless you splice in like 20 led's hehe
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-01-2003, 08:52 PM
Hmm...where could I stick all of those.....
Old 11-05-2003, 07:31 PM
Strider Strider is offline
Send a message via AIM to Strider Send a message via Yahoo to Strider
Get some green ones and stick them all around the inside edge of the bottom of the body.
need some info about light kits bengali548 XMODS Mods and Projects 3 08-02-2006 11:44 PM
Awd And Light Kits! shane-o XMODS 1 03-05-2004 06:59 PM
would anything fry if I rigged up like 8 more high output LEDs to a light kit? RGM1524 XMODS Mods and Projects 3 01-09-2004 10:29 PM
light kits Benskins XMODS Gallery 0 11-10-2003 08:23 PM
Head light kits Moto freak ZipZaps 0 12-23-2002 02:38 PM
