Old 10-31-2003, 01:01 AM
-CRX-
Wow!!!!
I went and bought a battery holder from radio shack tonight. http://www.radioshack.com/product.as...5Fid=270%2D414
i hooked the thing up with 2 extra batteries, holy sh*t this thing hauls, i have the skyline with the stage 2 motor with the 11 tooth. and the best part is the battery holder was only $1.06, and i already had the extra batteries.
Old 10-31-2003, 05:57 AM
lilcricket lilcricket is offline
Send a message via AIM to lilcricket
how did you hook it up...what connections did you make, and what problems can arise from adding this extra voltage?
Old 10-31-2003, 11:41 AM
xalex0000 xalex0000 is offline
Cool
Hey Crx, Thats neat dude, heyHow much time have you`ve driven your car on that setup ? Is esc holding? and how much is the run time with 7.2 volts of jucie . I dont know i i shuod just put one more cell an try to make the car lighter to be on the safe side . but 7.7 v would be great !
Thanks
Old 10-31-2003, 12:12 PM
-CRX-
ive been running it since last night, and all day today since like 8 this morning, i havent had any probs yet, and its taken about 45 minutes to kill my batteries, i have the radio shack rechargables.
Old 10-31-2003, 12:13 PM
-CRX-
from what i was told the motors can with stand the juice as long as your not driving it on carpet and overloading the motor or on any other rough surfaces.
Old 11-01-2003, 02:59 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
That is correct. The slower motors turn, the more current they draw. More current makes more heat in the motor, batteries, and FETs.
Old 11-01-2003, 03:16 PM
Bad Company's Avatar
I picked up one of those 2 "AAA" battery holders today and plan on trying this. I also noticed that had the "N" holders which were about half the size, so you could technically get more extra cells in there at the loss of capacity. The "N" cells were 1.2v also, but less mah. Can you run them with the regular "AAA" batteries?
Old 11-01-2003, 06:17 PM
-CRX-
yeah i saw those 2, i was thinking the same thing, im looking for some battery holders like the one that holds 2 aaa but i want 2 that hold 1 aaa and im gonna try and figure out a different way to mount them. ive discovered that with the pack were it is currentlty the car is really top heavy so if i make a really sharp turn it almost wants to roll. but i bought the supsension kit so this should help that.
Old 11-01-2003, 06:25 PM
Yeah, I went there looking for the single AAA holders too, but they didn't have them. I didn't see them on the site either.
Old 11-01-2003, 08:30 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
you should never run batteries of different capacities together. don't mix rechargeables and dry cells, nicd and nimh, different capacities, and different sizes.
a tip that i kinda learned from 1/10 rc's, keep the same four batteries you use in a set. the battery kit gets you 8 nimh batteries. separate them into two sets and keep them separated. always charge and use them together at the same time so they're a matched set. this gets you best performance and you won't have one cell depleting before the others
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 11-01-2003, 08:50 PM
Yeah, I have 4 sets of batteries, and each set has it's own corrisponding marks (1-4) so I keep them together.
I figured it wouldn't be good to mix capacities, so I didn't buy the "N" holder or batteries.
Old 11-02-2003, 02:57 PM
token5gtd token5gtd is offline
Send a message via AIM to token5gtd
pix
does nebody have some pics of waht the XMOD with the extra bat holder looks like, and a pic on how its wired, i know how to do it, but i wanna see a pic of one that works well
Old 11-18-2003, 11:23 AM
cmuench cmuench is offline
Supra king
Send a message via AIM to cmuench
Pic...
Heres my pic of my setup. I recently changed the quick disconnect to the same type that is used on the motor setup
**1997 Supra Xmod**
-Stage 10 Motor w/11 tooth
-AWD
-Wild body w/ Custom paint
-6 AAA battery mod (7.2v)
-Double head/tail light mod (Not used with 6 cell)
-Hard suspension w/ 4.5 toe-in
-upgraded wheels with hard tires
-Metal bearings upgrade
ec3s + stage 2 = wow! Metallica88 XMODS 4 03-10-2004 07:37 PM
WOW, another steering discovery! Upgraded steering motor! cyborgzero ZipZaps SE 2 02-22-2004 12:16 PM
Wow! Yell03SpecV XMODS 10 01-27-2004 01:33 PM
WOW! its here! PorscheGuy964 Tamiya M-Chassis Parts and Hop-Ups 6 07-04-2002 01:01 PM
