Old 10-31-2003, 12:17 AM
cashdog144 cashdog144 is offline
Squeeling?
When I first start up my XMOD and fully accelerate, it squeels. Then after a few minutes it goes away. Also when it squeels, the wheels seem to go slower. BTW, I'm running 2WD. If someone could help, that would rock.
Old 10-31-2003, 12:43 AM
dragon4450's Avatar
dragon4450 dragon4450 is offline
customanix
Send a message via AIM to dragon4450
your car is "jamming" someplace in the drive system i would recomend trying ot lube some of the points like the axels and such and see how that goes.
and then we added the giggle gas.
Old 10-31-2003, 09:21 AM
MadeInUSA MadeInUSA is offline
Send a message via AIM to MadeInUSA
I am having this same exact problem without the AWD kit and now it doesnt stop I have realized that it is because I need Lube but what Lube is the best to use I dont want to use something that is going to get dirt stuck in it even more im going to make a sepreate post to see what lube people are using.
Old 10-31-2003, 06:06 PM
I have a beach ball...
Mine did this before the AWD and after. The bearings need to be lubed. Like MadeInUSA, I don't know what kind to use. I have some shock oil sitting here from my brother's Micro RS4. Should I try it? If it screws it up I still have the nylon bushings to use until Tiny gets the bearings in the store.
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
Old 11-01-2003, 05:57 AM
airline2's Avatar
airline2 airline2 is offline
I Love Xmods
i would say it is the grease that comes with the awd kit
Current Xmods Setup
Skyline with stock body and stage one motor drift, awd, lights
Old 11-01-2003, 02:20 PM
vtheo's Avatar
vtheo vtheo is offline
Monoaural.
Send a message via AIM to vtheo Send a message via Yahoo to vtheo
I would use 3in1 oil, or sewing machine oil, something not so vicuos as grease as to go faster longer. wd40 would work too
J-On
Old 11-01-2003, 02:54 PM
mustang_steve's Avatar
mustang_steve mustang_steve is offline
the "too many tires" guy
Send a message via Yahoo to mustang_steve
I'd almost think graphite lube..like the kind you use in locks..at least it should last a long time.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
Old 11-01-2003, 03:01 PM
vtheo's Avatar
Monoaural.
hmm... remebers when i used lube on my bit.... yeah go with the graphite, or the lube rs sells, its not supposed to attract dust.
J-On
Old 11-01-2003, 10:07 PM
I used my mom's sewing machine oil and it work great, it's a lot qiueter now too.
Old 11-01-2003, 10:21 PM
War Eagle War Eagle is offline
This is from a thread yesterday. We have been using this and it seems to be great so far. Good Luck.
Precision Oiler with PTFE $2.99 at RS
Claims it won't attract dust or particles. So far, I like it. Seems to wear off sooner than the thick gunk, but when running it outside, I'd rather use this. Non-conductive.
Here's the link:
Old 11-01-2003, 10:25 PM
http://www.radioshack.com/product.as...5Fid=64%2D2301
Old 11-01-2003, 11:49 PM
Got 4.2 King? I do : )
where all do you use that oil on? will it mess up the motor if it gets in?
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 11-02-2003, 04:21 AM
you don't throw globs of oil on!
Just put enough on to evenly "wet" the gears.
All your trying to do it cut back on the friction...too much or too thick of an oil will actually reduce the effectiveness of the oiled part, as well as miake things inside your car's body a mess.
if you ever got to an autoparts store that has those oil treatment demo stands...you know...the ones wherer you turn the two cranks and look at the visible gears....spin the "treated" one real fast....what do you see? The oil moves rahter unnaturally, and you also feel it pull back on you. Sure you can't feel any roughness...the oil is so thick it took it out, but it also messed up your RPM limits. Funny part was they were trying to sell teh treatment, and all it did was assure me to not touch it with a 10ft pole
Body Kit
Stage 2 drag motor
Hard tread Tires
NiMH batteries
Yellow Skyline RWD
Stage 2 Drag motor
4.5 Tie Rod
Soft Tread Tires
Squeeling noise from inside. zipinzapin ZipZaps Monster Truck 19 03-06-2006 06:03 AM
