10-29-2003, 07:41 PM
Serious Problem...
I just got my XMOD today, lol the first Skyline I bought sucked, so I took it back, the second one was much better. But moving on to my problem...My Skyline has a problem with the wheels...For one the right rear wheel wont screw in all the way, and its kind of loose, then on the two front wheels, they are not straight, and i used the straighting function on the controller, but no sucess....Do the Skylines have this problem? Is there anyway to fix it? Or should i take this one back as well??? Thanks in advance.
Ryan
"Theres no Shame in my Game!"
10-29-2003, 07:47 PM
As for your loose wheel problem...
Some of the cars have axle pin threads that are longer than the depth of the lugnut. You can do one of two things. Drill out the end of your stock lugnut so the threads can go thru, or buy some aluminum lugnuts which are open ended to begin with.
As for your straight wheel problem, you can try to remount the servo horn. You can find a link to a tutorial in my signature...
10-29-2003, 08:04 PM
I have a beach ball...
Wow, I made it to BC's tutorial list
'65 Ford Mustang
All the RS goodies
Becoming a donor car for:
'04 Ford Mustang Cobra
10-29-2003, 08:12 PM
It's not mine, it's the "member's" tutorial list, you guys are the ones who put the stuff together!
10-29-2003, 10:35 PM
Got 4.2 King? I do : )
if you dont have a drill you can just take an xacto knife and cut off the nub on the nut, thats what i'm doing i started 2
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
10-30-2003, 09:36 AM
Thanks guys, I did what you said in the Tutorial and it helped, althought i still need to do some modification to it, see it goes good then when I hit top speed it curves....I'll check it out.
11-01-2003, 06:30 PM
Know of any place that I could buy those lug nuts?
11-01-2003, 11:49 PM
I dunno what's around you, but my LHS had some lug nuts for a micro RS4 for .75 cents with tax. I put them on and my wheels don't wobble anymore.
'65 Ford Mustang
All the RS goodies
11-03-2003, 04:18 AM
the "too many tires" guy
ah, just cut teh center bit of your nylon lugs out....the contrast also looks rather nice too
EDIT: I found out why the centers are closed like that, structural strength, cracked a few lugs that way. Oh well, time to go to mr. metric and buy some nuts to replace em.
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
11-03-2003, 10:40 PM
Skyline
My first Skyline i bought ran for about 25 seconds, then something shorted out. I took it back, they replaced it, and I haven't had a problem w/ it yet. It made me kind of wonder, after owning a kyosho miniz, and a micro by hpi.. if radio shack had a couple of bugs to work out. After all, they're new to the game.
11-08-2003, 04:02 PM
I bought a set of 2mm lug nuts from a mini-z they are aluminum and they are anodized purple so they look sweet as well.
